Thread Closed
silly question about pull-ups
Share Thread Thread Tools
Oct8-03, 12:14 AM   #1
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
When it comes to doing pull-ups (or chin-ups) does difficulty depend on where the individual's center of mass is? Someone I know contends that pull-ups are more difficult for females because they have lower centers of mass. It seems to me though that center of mass shouldn't matter for this particular exercise; so for instance if I moved my center of mass down 1 foot, it shouldn't make a pull-up more difficult as long as my net weight remains constant.
What say you physics knowing peoples?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Soft matter offers new ways to study how ordered materials arrange themselves
>> Making quantum encryption practical
Oct8-03, 12:27 AM   #2
Recognitions:
I don't see how it would matter either. As soon as your feet are off the ground, you're a pendulum -- and your center of mass will experience a restoring torque which will push it directly under the pivot. Once the center of mass is directly under the pivot, I see no way its vertical distance could make any difference.
I'd say women have a harder time with pull-ups and chin-ups because their genetics don't encourage as much upper-body musculature.
- Warren
Oct8-03, 01:44 AM   #3
yea verily.
Oct8-03, 01:48 PM   #4
Recognitions:
The point is not whether the center of mass is high or low but how much it is raised. A person with longer arms who raises his/her center of gravity more would do more work.
Oct8-03, 01:51 PM   #5
Muscle insertion plays a role, too.
Oct11-03, 02:22 PM   #6
Halls is right,
a female with a lower center of mass has to do more work. for example consider a boy and a girl of 75 kilograms the distance to the boys center of mass from his vertically outstretched arms is .5 meters, and the distance to the girls is .5+x meters than the energy required to do a pull up for each of them is.
Boy = 75*g*.5
Girl = 75*g*(.5 + x) = 75*g*.5 + 75*g*x
meaning it takes more energy for the girl to do a pull up.
Oct11-03, 02:33 PM   #7
Mentor
Originally posted by VBPhysics
Halls is right,
a female with a lower center of mass has to do more work. for example consider a boy and a girl of 75 kilograms the distance to the boys center of mass from his vertically outstretched arms is .5 meters, and the distance to the girls is .5+x meters...
So girls have longer arms than boys? Do they? (hint: no).
And that wasn't Halls's point. His was a hypothetical - IF one person had longer arms than another of the same mass, it would take more energy. Someone tall and skinny has to work harder than someone short and fat (and the same mass).
And if you want to be picky, adult males being taller on average have longer arms than adult females do.
Oct11-03, 02:45 PM   #8
Dear russ, thank you for your sarcasim(hint: your misinterpreting the problems setup)
the x is meant to denote the lower center of mass that the girl would have --not some change in the arm length between the two people. give them identical heights, and appendage lengths, and the girl is still going to have a lower center of mass than the boy. Unless they are swinging around the bar like a pendelum, and even then her's will be lower until they swing above the bar.
Hall's point, and mine is not that girls have longer arms. It is that if a person is raising the point at which force is acting on them over a longer distance. than that effort requires more energy, and is thus it is harder to perform that effort.
Oct11-03, 03:44 PM   #9
Recognitions:
[The point] is that if a person is raising the point at which force is acting on them over a longer distance...
And how does anything but arm length affect the distance one raises that point?
Oct11-03, 06:30 PM   #10
Recognitions:
But Hall's point was that having a lower CoG had no effect on the effort needed, but having longer arms did. This is not the same as what you said, which is that girl's, having a lower CoG, would exert more effort. The intial position of the CoG has nothing to do with how for it is raised, while the arm length does. Remember, the object of a pullup is to get your chin over the bar, not your CoG.
Oct13-03, 04:55 PM   #11
Recognitions:
But a female's lower center of gravity is closer to the Earth's, so it would have a stronger pull. Of course thier shorter arms would put them higher up, so maybe it evens out. But the combination of lower COG and shorter limbs gives the female a decided dissadvantage in doing squats.
Oct13-03, 08:31 PM   #12
Doc
Do you recall weighing less on the top floor of a building compared to the basement? At least enough to matter? Give me a break.[g)]
Oct13-03, 09:18 PM   #13
Mentor
Lol, gotta give you that one.
Dear russ, thank you for your sarcasim...
Damn, and I thought I was being nice - explaining that you had misinterpreted what's going on here, without trying to cut you off at the knee.
If you want to see some REAL sarcasm from me check the politics forum out - or that thread on expanding earth. I can be downright nasty.
Oct14-03, 07:35 PM   #14
I now see where you got the x being the arm length. I was trying to put the CoG over the bar. Something tells me that the fact that you edited that post before I saw it was a good thing.
We have a politics forum?
Oct15-03, 07:15 AM   #15
pmb
The vertical location of the center of mass is not important. Where the arm connects to the body implies that the arm-lever does not know where the vertical location of the center of mass is.
The lenght of the arm is important since doing pullups you're using the arm as a lever.
However muscle is important here. There is an effect that is very important that has been overlooked in this thread so far. And that is the idea of ratios.
Suppose you take a look at this only from a physics standpoint and not from a muscle efficiency etc point of view. Consider a person of a certain height and weight. His muslces have a certain cross-sectional area. Lets assume that the strength of the man is proportional to the cross-sectional area of the muscle. Now if the man doubles in size such that all his physical dimesions increase in direct proportion then the cross-sectional area of the muscle will double in size. However his weight has now increased 4-fold. So he got twice as strong but now he has to lift 4 times the weight! That tanslates to less pullups.
Pmb
Oct23-03, 04:41 AM   #16
One issue that nobody's looked at is that a pull-up doesn't happen directly under the bar. It happens off to one side, especially as you finish the pull-up. That means that you're not just pulling straight up--you also have to hold your center of mass out. Since men have a higher center of mass, they have to hold it out at a greater angle. Therefore, center-of-mass alone means men do harder pull-ups.
Oct24-03, 01:08 AM   #17
Mentor
Nice catch. I actually did think of that as I'm relatively skinny and thats a problem for me doing pullups - I start swinging back and forth. To compensate I lean back(or rather pull my legs up in front of me), but then that just means I'm lifing my COG further than if I could lift myself straight up.
Besides where your COG is located though, this is also due to muscle geometry. Your biceps lift your body up at the shoulder while your lats just pull your body forward to meet your elbow.
Thread Closed
Thread Tools
Similar Threads for: silly question about pull-ups
Thread Forum Replies
Gravitational Pull Question Introductory Physics Homework 3
Silly question but uhh Introductory Physics Homework 3
silly question.... Calculus 2
Silly NMR Question Chemistry 3
very silly question... General Astronomy 5
