Why does Electromagnetic Radiation move?
The discussion revolves around the nature of electromagnetic radiation (EMR) and the mechanisms behind its propagation. Participants explore theoretical frameworks, models, and conceptual understandings related to how EMR moves from sources, such as alternating magnetic fields in light bulbs, and the implications of these mechanisms in physics.
  • One participant questions why electromagnetic radiation (EMR) travels outward from a source, such as a light bulb, and seeks ideas on the underlying principles.
  • Another participant explains that EMR follows from Maxwell's equations, highlighting the relationship between changing electric and magnetic fields and suggesting a self-sustaining mechanism for EMR propagation.
  • A different viewpoint suggests that the momentum of EMR is a consequence of its movement, challenging the idea that it moves because it has momentum.
  • Some participants express a preference for different models of electromagnetism, such as Purcell's model or quantum electrodynamics (QED), indicating that personal intuition varies among individuals.
  • Concerns are raised about the potential for oversimplification in explanations of EMR, with some participants advocating for accurate and thorough descriptions to avoid misconceptions.
  • There is a discussion about the difficulty of determining the origins of electric and magnetic fields experimentally, with references to the self-sustaining nature of these fields.
  • Participants reflect on the pedagogical approaches to teaching complex ideas in physics, emphasizing the balance between simplicity and accuracy in explanations.
Participants express differing views on the nature of EMR and the models used to describe it. There is no consensus on the best approach or explanation, and the discussion remains unresolved with multiple competing perspectives presented.
Some participants note the limitations of simplified explanations and the potential for misconceptions, emphasizing the importance of accurate representations of physical phenomena.
pkc111
What law is being obeyed by emr traveling out from a source eg a magnetic field does not get emitted from a magnet, why does a magnetic field get emitted (eg travel outwards at speed of light) from the alternating magnetic field present in a light bulb for example?
I would appreciate any help with ideas :)
Thanks
Electromagnetic radiation follows from Maxwel's equations, and is a consequence of the rules for how electricity and magnetism work. All that stuff about charged particles and currents.
You know that a changing electric field produces a magnetic field.
You know that a changing magnetic field can make an electric field.
So it is reasonable to suspect that one can manipulate an electric field in such a way that the resulting magnetic field will create an electric field that creates the same magnetic field and so on and on and the setup becomes self-sustaining.
It turns out you can do this - except that, at each "iteration", the new field has to be slightly advanced in space. i.e. the resultant form has to travel. (You can see how this works in a simpler context in cellular automata - look it up.) The (invariant) speed of the travel is a property of space-time. The speed in media is a material property.
The energy comes from whatever made the initial variation in the field ... per your comments, the magnet does not lose magnetism to make radiation, but someone had to shake it to make the B field vary. The energy in the radiation comes from whatever did the shaking.
In the light-bulb, the electricity makes the filament hot and the heat makes the light, and we are approaching QM. It will help to stick to the classical descriptions while you are getting used to how radiation works.
However - this is an area where the best description is the mathematics.
Words are not going to do it very well.
pkc111,
Simon Bridge has given a good verbal introduction to electromagnetic radiation. He's also correct to remind us that mathematics is the only thorough and complete method to fully grasp this phenomenon of nature.
But, you can read this, and study the English words with no mathematics at all, and learn an immense amount about this radiation. Try it:
http://en.wikipedia.org/wiki/Electromagnetic_radiation
Because it has momentum.
Different people like different models. There's nothing wrong with that as long as the model you choose makes correct predictions. Personally, I never liked Maxwell very much. I find Purcell's model or the QED model to be more intuitive.
Here's a good explanation of Purcell's model of electromagnetism...
http://physics.weber.edu/schroeder/mrr/MRRtalk.html
And here's a very old, but very well presented explanation of QED...
I'd have to strongly disagree with that response because EM radiation has momentum because it moves. Not the other way around.
One can also visualize what EM radiation moves by considering what happens to a test charge as one moves it. The field meaured at a distance from the charge has a certain magnitude and direction. When the charged is moved then the magnitude and direction of the field must also move since the later configuration results in a changed magnitude and direction of the force on the test charge. This disturbance in the field propagates at a finite speed, i,e, the speed of light.
Regarding the following statements
It seems like almost all textbooks explain things like this. The problem is that you can't determine by experiment why a magnetic/electric field is produced. All that you can do is to say that where there is a time varying E field you will find a time varying B field and vice versa. I recall an journal article pointing this out. I'll see if I can dig it up and post the reference and hopefully it will have an abstract I can quote.
You mean, you cannot determine what, in particular, gives rise to the EM field?
The chicken and egg thing?
This is just a way of impressing the starting student with the existence of a self-sustaining solution.
You are right - one should not think of it as one after the other.
I usually think of that as the next stage in the thinking - but if you have had success getting these ideas across in one go - more power to you :)
Simon Bridge said:
You are right..
I love it when that happens. :)
Simon Bridge said:
... - one should not think of it as one after the other.
I've learned from many years of experience talking to people trying to learn physics that its best not to give them ideas for simplicity merely to get it across faster if its something that they'll have to unlearn in the future. It is my belief that it's much better to explain things correctly the first time even if its hard to grasp so that later they won't have to unlearn anything, which might be hard to do. For example; I can't count how many times I've had to explain to people that radiation is not pure energy. Just hearing that gives me the willies.
I even heard an old coworker of mine, who had an MS in medical physics, once answer the questrion "What is light" with "It's energy!" ... sigh! :)
There is a nasty habit in some quarters of giving glib "throwaway" answers in the name of getting a simple version of the idea across ... and this can cause problems later. The questions we get here from people watching Discovery Channel being great examples of the problems that arise.
On the other hand - it also leads to problems if we try to deliver too much in one go.
Established pedagogy favors a scaffolding approach - where simpler ideas are used to lead into more complicated, or just more complete, ideas. Students often have to throw away old scaffolds when they have outlived their usefulness.
So much fr being general.
The "feedback" description for how Maxwel's equations lead to radiation is one such. It is a small jump from iterative feedback idea to the simultaneous self-sustaining solution so, in this particular case, it is not something that is hard to unlearn. I have found it is a good idea to spell out, every now and again, that the short wordy answers are only simplifications to "get the idea" though - otherwise people tend to run with them just a tad too far.
Simon! M'man! I couldn't have said it any better myself.
I agree. I just ran into that in another thread. One person wanted to know the answer to a simple question so I answered it having learned the answer from reading and from a friend who is a well known expert in the field. I know GR fairly well but have never derived such a proof even if on exists. My friend told me that it was what most specialists in that field believe and not that it can be shown/proved. That makes a huge difference. So I posted what I was informed that they believe. Bothering with a derivation is a waste because I have other things I'm more interested in doing plus the OP wouldn't have understood the response because the math of GR is extremely difficult.
Thanks.
In my opinion there is too much didactics and too little common sense in teaching, particularly from the socalled professional didactics. In physics you should not teach old-fashioned outdated ideas, if the newest views are as simple or even simpler than the old ones.
One example is classical electromagnetism. There you have a quite simple set of equations for the fundamental issues of charges, currents, and the electromagnetic field. These are the Maxwell equations in differential form. Of course, you have to learn vector calculus first, but that can be done very well with the right physics pictures at hand, and electromagnetism is a great arena to learn also these mathematical tools.
This view is underlined if you look into the history of physics. One of the most successful (theoretical) physics teachers ever was Arnold Sommerfeld. I guess, it would be difficult to find someone else with more Nobel-prize winners under his or her students than him. If you read his textbooks on classical theoretical physics, you see that they were approaching the problems with the right mathematical tools and without unjustified "simplifications" but explaining the problems and their solutions in a very clear and concise way. It's an example for a very fruitful unity of research and teaching (the Humboldt ideal of university pedagogics).
Modern didactics on the other hand has the tendency to invent strange ideas of how to teach things. In Germany there is a big debate about the socalled "Karlsruhe Physics Course", which now is about 40 years old, but never has ever become a mainstream way to teach physics, because it is decoupled from the way the physics community is used to do physics. E.g., they do not start with good old Newtonian classical mechanics, which is the backbone of any start in learning physics (if you ask me), because they think that it's easier to think in terms of fluid-dynamical continuum ideas. So instead of forces they introduce momentum fluxes, which of course is not really wrong in the first place. Of course you can formulate all classical mechanics as fluid mechanics and with help of the various hydrodynamical equations (Euler-perfect fluid, Navier-Stokes viscous fluid, and so on), but first of all I'd not think that this is a good start for a freshmen to learn physics and second if you want to do it right, the math needed is much more demanding than the relatively simple ordinary differential equations, making up Newton's theory for point-like classical objects with forces acting on them, causing acceleration due to Newton's three laws of motion. In thermodynamics they claim, heat is the same as entropy, in electromagnetism they discuss magnetic monopoles right from the beginning although there is not the slightest hint of their existence. So it's well understandable und in my opinion very fortunate, why these "didactics" has not found many followers. Now the ministry of education in one of the German states wanted to introduce this (sorry to say it so harshly) nonsense into their (high) schools, and the German Physical Society was ask for a recommendation, whether one should do that. Of course, the committee checking this educational concept for scientific content and accuracy came to a very clear negative conclusion, strongly disagreeing to the whole concept to introduce physics to high-school students. Now a big debate is going on among the didactics section and the various other sections of the German Physical Society about this harsh but very justified judgement.
It's good to listen to Einstein, who said: "Try to simplify issues as much as possible but not more."
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 16 ·
