Difference between polarized and non polarized capacitors
The discussion centers around the differences between polarized and non-polarized capacitors, exploring their construction, applications, and reasons for the existence of both types. Participants delve into technical aspects, manufacturing challenges, and cost considerations.
  • Some participants note that non-polarized capacitors are harder to manufacture at small sizes compared to their capacitance, leading to larger physical sizes and higher costs for higher capacitance.
  • Others argue that polarized capacitors allow for smaller sizes and higher capacitance, but they come with the limitation of being polarized, which can restrict their use in certain applications.
  • One participant mentions that electrolytic capacitors provide a way to achieve high capacitance in a compact form but are polarized and have a finite lifespan.
  • Another participant explains that electrolytic capacitors can be connected back-to-back to create a non-polarized version, although this approach significantly increases the cost.
  • A technical explanation is provided regarding the manufacturing of electrolytic capacitors, highlighting the importance of surface area and dielectric thickness in achieving high capacitance.
Participants express differing views on the advantages and disadvantages of polarized versus non-polarized capacitors, indicating that multiple competing perspectives remain without a clear consensus.
Limitations include the dependence on specific applications and requirements for capacitor types, as well as unresolved discussions on cost implications and performance characteristics.
hisham.i
Hello,
I googled the difference between polarized and non polarized capacitors and all i found was differences in construction and the material that they are formed from.
I want to know why there is 2 types of capacitors, what are the differences (cost, technical, etc), why there is not only non polarized?
thanks
Non-polarized capacitors (the ones we learn about in physics at first), at hard to manufacture at a small size compared to their capacitance (they become very big if we want a big capacitance). Also, they can be quite expensive when they become bigger.
Polarized capacitors give us a way to manufacture smaller capacitors, but with a high capacitance. The drawback however, is that they are polarized.
Some places with high requirements, it is not allowed to use polarized capacitors.
Electrolytic capacitors are a way to manufacture a high capacitance relatively cheaply and in a small sized package. They are definitely a compromise, and have a finite life.
You can connect two electrolytic capacitors back-to-back (electrically) so as to form a non-polarized electrolytic capacitor. Obviously, it will be about 4 times the cost of a single polarized capacitor giving the same capacitance.
The answer to your question is:
Electrolytic capacitors pack thousands of times more capacitance into a given volume than you can get with film dielectric types.
But - electrolytic capacitors are necessarily polarized because of how they're made..
capacitance= area / distance.
Area is the area of the foil
Etching an aluminum foil gives it more surface area per square inch. The microscopic hills and valleys have more surface area than would a mirror flat sheet. Remember the old saying "Colorado would be bigger than Texas if you ironed it flat" ?
Etching gives a large [STRIKE]denominator [/STRIKE] NUMERATOR (golly I'm doing everything backward today !)
Distance is the thickness of the dielectric.
In electrolytics the dielectric is not a plastic or paper film but a thin layer of aluminum oxide on one the aluminum sheets. It's only a few atoms thick so you have a very small denominator.
This little paper by Cornell-Dubelier explains it well.
http://electrochem.cwru.edu/encycl/misc/c04-appguide.pdf
old jim
  • · Replies 32 ·
  • · Replies 78 ·
18K
  • · Replies 25 ·
