Value of parallel capacitance necessary to achieve a Power F. of unity
The problem involves determining the value of parallel capacitance required to achieve a power factor of unity for an AC induction motor with a specified complex impedance at a given frequency.
  • Participants discuss the relationship between the motor's impedance and the required capacitance, exploring the concept of power factor and its implications on the impedance's imaginary component. Some participants question the interpretation of "power factor of unity" and its mathematical representation.
The discussion includes various approaches to calculate the necessary capacitance, with some participants confirming the correctness of mathematical expressions and exploring alternative methods such as using admittance. There is an ongoing examination of the implications of the calculations presented.
Participants note the importance of understanding phasors and the implications of sinusoidal voltage excitation in the context of the problem. There is mention of the need to clarify definitions and assumptions related to the power factor and impedance.
anol1258
The electrical model of an operating AC induction motor yields an impedance, Z, of 18.65+j15.106Ω . What value of parallel capacitance is necessary to achieve a power factor of unity if the operating frequency is 60Hz?
V=IR
w=2pif
P=VI
I know the reactance of a capacitor is 1/jwC. And impedances add like 1 over the sum of reciprocals.
Put the complex impedance of the motor in parallel with a capacitor. Then force the parallel combination Z (or Y) to be real by appropriate selection of the capacitance.
PS if you haven't had phasors you'll have to write the differential equation for the total current given a sinusoiudal voltage excitation, and solving for the value of C that will give zero phase shift between excitation voltage and total current.
so far I have the impedance of the parallel combination as:
[itex]\frac{1}{\frac{1}{Z}-\frac{ωC}{j}}[/itex]
where Z is the given complex impedance of the motor. What can I do from here?
Just to clarify, I think when it says "power factor of unity" it means a ratio of 1:1
"power factor of unity" means zero imaginary component of the total impedance (current in phase with the voltage).
Your expression for total Z is correct. Now substitute the given expression for motor Z, compute C such that the imaginary part of the total Z = 0. Remember what w is.
[itex]\frac{1}{0.032377-j0.026225+377jC}[/itex]
So...if I do...
-0.026225+377C=0
and solve for C...
C=69.56μF
Math correct?
The value that you found is correct.
Another approach might be to first turn the motor's impedance into its equivalent admittance; Y = (1/Z). Parallel admittances simply add (like conductances do), rather than all that inverse of the sum of the inverses stuff you need for impedances. That means you can pick out the magnitude of the required admittance of the capacitor directly from the admittance of the motor -- it's the imaginary term. Capacitor admittance is just ##j2\pi f C = j \omega C##.
  • · Replies 16 ·
10K
10K
22K
