Cauchy sequence and convergeant diameters.
  • Thread starter Thread starter gottfried
    Cauchy Sequence
The discussion centers on the relationship between Cauchy sequences and the convergence of diameters in metric spaces. It establishes that a sequence (an) in a metric space X is Cauchy if and only if the diameter diam Tn converges to zero. The participants clarify that Tn is defined as the set {ak:k>n} and that the diameter is computed using the metric of X, although it is noted that the diameters are real numbers, likely interpreted under the natural Euclidean metric.
  • Understanding of Cauchy sequences in metric spaces
  • Familiarity with the concept of diameter in metric spaces
  • Knowledge of the Euclidean metric and its properties
  • Basic principles of convergence in mathematical analysis
  • Study the properties of Cauchy sequences in various metric spaces
  • Explore the concept of diameter in different metric contexts
  • Investigate the implications of convergence in metric spaces
  • Learn about the relationship between different metrics and their induced topologies
Mathematicians, students of analysis, and anyone interested in the properties of sequences and convergence in metric spaces.
gottfried
Suppose (an) is sequence in the metric space X and define Tn={ak:k>n} and diamT=sup{d(a,b):a,b elements of T}.
Prove that (an) is Cauchy if and only if diam Tn converges to zero.
In what metric spacee does Tn converge? I assumed in (ℝ,de) but this is confusing since the diam of T is measured using the metric of X.
##T_n## is set in space X.
##\mathrm{diam} \ T_n## are real numbers, and nothing is said what metric is to be used on them. Which probably means the "natural" Euclidean metric.
That makes sense, thanks.
