Find interval for contraction map
The discussion revolves around finding an interval [a, b] for which the Contraction Mapping Theorem can guarantee convergence to a positive fixed point for the function defined by g(x) = (14/13) - (x^3/13). Participants are exploring the conditions under which the derivative of g, g'(x), satisfies the contraction criteria.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to determine the appropriate interval by analyzing the derivative g'(x) and its bounds. There are questions about the validity of certain inequalities and the implications of the values derived from them. Some participants express confusion regarding the relationship between the derived interval and the location of the root of the equation.
The discussion is ongoing, with participants providing guidance on how to approach the problem. There is a mix of interpretations regarding the derived inequalities and their implications for the interval. Some participants are questioning assumptions about the root and the derived bounds.
There is uncertainty regarding the specific values and intervals that satisfy the contraction mapping criteria, as well as the implications of these values in relation to the root of the function. Participants are also navigating the constraints of the problem as posed in the homework statement.
Unredeemed
Find an interval [a, b] for which the Contraction Mapping
Theorem guarantees convergence to the positive fixed point or verify that there is no
such interval.
[itex]x = g(x) = \frac{14}{13} - \frac{x^{3}}{13}[/itex]
I know the solution is slightly greater than 2. So, I assumed the upper bound on my interval would be 3 and g(3)=-1. So, I picked my lower bound to be -1 so that the function mapped from [-1,3] to [-1,3]. But, I'm having trouble showing that:
[itex]abs(g'(x)) \leq γ[/itex] for some 0 < γ < 1.
Any help would be massively appreciated.
The latter inequality is what you should use to find the interval. Find g'(x), and see in what interval the inequality is satisfied.
I've found that [itex]abs(g'(x)) < \frac{\sqrt{39}}{3}[/itex]
But, this value is less than [itex]\sqrt[3]{14}[/itex] which is obviously the root. So is there no interval?
Where does ##\frac {\sqrt {39} } {9}## even come from?
Regardless, this is NOT what you want. You need to let ## |g'(x)| < 1 ## and find the interval satisfying that.
But if we want ## |g'(x)| < γ ##
And ## |g'(x)| = \frac{-3x^{2}}{13} ##
So ## |\frac{-3x^{2}}{13}| < γ ##
And then ## |x^{2}| < \frac{13γ}{3} ##
Implies ## |x| < \sqrt{\frac{13γ}{3}} ##
Then ## |x| < \frac{\sqrt{39}}{3} ## since ## γ < 1 ##
No?
You got ##|x| < r##, which is what you want. Compare that to #3.
Sorry, I don't understand what you mean?
In #5, you got the interval for x where g'(x) satisfies the contraction map criteria. In #3, you got some bogus inequality.
So is my interval ## [-\frac{\sqrt{39}}{3},\frac{\sqrt{39}}{3}] ## ?
Because that doesn't contain a root of the equation?
Sorry, I'm very confused.
What makes you think so?
Well ## \frac{14}{13} - \frac{(\sqrt[3]{14})^{3}}{13}=\frac{14}{13}-\frac{14}{13} = 0 ##
So that's the root?
That's the zero on the RHS. You still have a non-zero LHS.
  • · Replies 24 ·
