Angular Momentum in a Kepler Orbit
The discussion centers on the angular momentum of a satellite in a Kepler orbit around planet X, initially calculated as 1000 m²/sec based on its distance, mass, and velocity. When a second planet, planet Y, is introduced, the total mass of the system increases to 2.0 kg, but the radius and velocity of the satellite remain unchanged. Consequently, the angular momentum of the system does not increase, as neither the momentum nor the radius has changed, although the satellite's trajectory will shift from a circular to an elliptical path.
  • Understanding of angular momentum and its calculation
  • Familiarity with Keplerian orbits
  • Basic knowledge of gravitational forces and constants
  • Concept of conservation laws in physics
  • Study the principles of angular momentum conservation in multi-body systems
  • Explore the mathematical derivation of Kepler's laws of planetary motion
  • Investigate the effects of gravitational interactions on satellite trajectories
  • Learn about the transition from circular to elliptical orbits in celestial mechanics
Astronomy students, physicists, and anyone interested in orbital mechanics and the dynamics of satellite motion in gravitational fields.
Rapidrain
I got myself here a satellite rotating at a large distance around planet X.
Distance from center of planet X = 100,
mass of the satellite = 1 gram (really small),
mass of planet X = 1.0 kg
velocity of my satellite 10 m/sec
and in this oddball universe the gravitational constant = 10**4
So the satellite-planet X system has an angular momentum of 100 * 10 = 1000 m**2/sec
Now suddenly I place a second planet, planet Y, right next to planet X
mass of planet Y = 1 kg
So at this instant, the central gravitational source is now 2.0 kg but distance is still 100 and velocity of satellite is still 10
My question : has the angular momentum of the system increased?
I'd like to use angular momentum conservation to figure the characteristics of a
satellite / planet / planet trajectory. That's where I'm going with this.
Hi Rapidrain! :smile:
Angular momentum = radius "cross" momentum.
Neither the momentum nor the radius has changed, so the angular momentum is also the same.
The satellite will follow an ellipse instead of its original circle.
  • · Replies 40 ·
  • · Replies 28 ·
  • · Replies 16 ·
