Abstract in my bachelor's thesis
  • Thread starter Thread starter Lovendick
    Abstract Thesis
The discussion revolves around the challenges faced by a student in writing the abstract for their bachelor's thesis, specifically focusing on terminology and grammar in the context of a research project involving copper's conductivity and processing methods. Participants provide feedback on the abstract's language and clarity, as well as suggestions for improving the expression of ideas.
  • Meta-discussion
  • Some participants point out grammatical errors, such as the misuse of "it's" instead of "its" and suggest clarifications regarding terminology.
  • There is a discussion about the phrase "researching hot spots," with suggestions to rephrase it to "hot topics in research."
  • Participants question the meaning of "lower intensive" and suggest that the student clarify what is meant by intensity in the context of copper.
  • Concerns are raised about the clarity of the abstract, particularly regarding the description of materials and processes used in the experiment.
  • Some participants suggest that the student should use present tense when discussing the thesis, as it reflects ongoing discussion rather than completed actions.
  • There is a suggestion to simplify the term "electrical copper" to just "copper," unless a specific distinction is necessary.
Participants generally agree on the need for grammatical corrections and clarity in the abstract, but there are differing opinions on specific terminology and phrasing. The discussion remains unresolved regarding the best way to express certain concepts.
Limitations include potential misunderstandings of terminology and the need for clearer definitions of terms like "electrical copper" and "intensity." There is also uncertainty about the appropriate tense to use in the abstract.
This discussion may be useful for students working on academic writing, particularly in STEM fields, who are seeking feedback on language and clarity in their abstracts or theses.
Lovendick
well,I'm not quite sure is it appropiate to post this here. I'm just here for some help...
I‘m a Chinese senior student in college. When I'm writing the abstract in my bachelor's thesis,I've got some trouble—— terminology and grammar.
As you know,my English is not that good to write an english abstract easily.And many terminology cannot be googled in google translate. So I’m here to ask for some help——help me to find out the mistake in my abstract:
abstract:
   Copper is widely used in many fields because of it’s outstanding electric conductivity. Especially in the electrical and electric domain, copper is unreplaceable. But due to it’s lower intensive and the difficult of keeping a high intensive while enhancing it’s conductivity, how to intensify the copper without reducing it’s conductivity is one of researching hot spots currently.
   The materials of the experiment is electrical copper that used in the enamel-insulated wire. We used the Φ8mm electrical pure copper wire that produced by SCR method as a raw materials, then processed it into Φ0.3mm wire with two processes. We discussed each stretching and annealing process’s influence on the properties of the copper, analyzed the micro organization of each procedure. And compared and contrasted two processes.
   The research discovered that stretching process is a work hardening process to the copper. It makes grains fibrous, intensifies the copper and reduces it’s elongation and conductivity. On the contrary, annealing process makes grains smaller. Improve the elongation and conductivity, reduce the intensity.(compared with the sample that didn’t annealed, it’s intensity still improved) It is worth to be mentioned that after a high working rate stretching process, intensity reduced unnaturally. And in the following annealing profess, grains grow up unusually. This is going to have a negative influence on the sample.
I had a look at the first two paragraphs, but I am not a native speaker, so I am sure others can do it better.
it’s -> its everywhere. "it's" would be "it is".
Do you mean "electric and electronic"?
I would remove "but". What is a "lower/higher intensive"? If you mean intensity: intensity of what? Do you mean mechanical stability in some way?
I would begin this part with the "researching hot spots" ("hot topics in research"?) and come to "how to..." afterwards.
"materials ... are" (several materials) or "material... is" (one material). Where is the difference between "electrical copper" and other copper?
"that is used [...]?
See the previous 2 quotes, and I think I would explain "SCR method" in an abstract.
Does "raw material" refer to the Φ8mm copper wire? Do you make a Φ0.3mm wire based on that? I think I would split that sentence.
We discussed
Did you do that in the past, or do you discuss it in your thesis?
"and analyze the ..."
"The two processes are compared"? This should be clear from the explanation given before, I think I would drop that.
I'm so greatful for you response,thank you for your time. and I still have some question about your answer
about"I would begin this part with the "researching hot spots" ("hot topics in research"?) and come to "how to..." afterwards."
——Do you mean that I should say it in this way:One of researching hot spots currently is how to intensify the copper without reducing it’s conductivity.about""materials ... are" (several materials) or "material... is" (one material). Where is the difference between "electrical copper" and other copper?"
——I used to think that "electrical copper" is the copper that be used as a conductor or something else in the electrical industry. If not, how should I describe it?
about "Did you do that in the past, or do you discuss it in your thesis?"
——I just discuss it in my thesis. You mean I shouldn't the past tense?
Something like that, yes. "researching hot spots" is... hmm, I don't know.
It is "its", not "it’s".
As long as this material is not something special, I think I would just call it "copper".
Past tense would indicate that it has been done in the past.
well, I see,thanks for your help again.I'll spend a lot of time to find out those mistakes without your help.
  • · Replies 21 ·
  • · Replies 19 ·
11K
