Lift of a helium spherical balloon
The discussion centers on the mechanics of how a helium-filled spherical balloon rises, exploring concepts of buoyancy, pressure differentials, and the role of gravity. Participants examine the phenomenon from both conceptual and theoretical perspectives, considering molecular interactions and principles of physics.
  • One participant questions how a perfectly spherical helium balloon rises, suggesting that equal gas collisions and pressure on all sides would imply no net upward force.
  • Another participant counters that atmospheric pressure decreases with altitude, creating a pressure differential that contributes to buoyancy.
  • A later reply acknowledges the importance of pressure disparity, questioning the balloon's ability to rise in a hypothetical scenario without such disparity.
  • Some participants assert that balloons rise due to the difference in weight between the helium inside the balloon and the weight of the air displaced, referencing Archimedes' Principle.
  • One participant highlights the significance of pressure gradients in creating buoyancy, stating that without a pressure gradient, buoyancy would not exist.
  • Another participant draws an analogy to floating point number accuracy in computing, suggesting that small differences in pressure can be accurately measured despite being nearly equal.
Participants express differing views on the mechanisms behind the rise of helium balloons, with some emphasizing pressure differentials and others focusing on weight differences. The discussion remains unresolved, with multiple competing perspectives presented.
Participants explore the implications of pressure gradients and buoyancy without reaching a consensus on the primary factors influencing the rise of helium balloons. The discussion includes hypothetical scenarios that challenge the established principles of buoyancy.
ayueh1007
So I was pondering this question: On a conceptual level, how does a perfectly spherical helium balloon rise?
I understand that the density of helium gas is lower than that of our atmospheric composition of gases, but that is not giving the full perspective for me. On a molecular level, I feel like it WOULDN'T rise (despite my experiences in person). My logic behind this is:
-A perfect spherical balloon has no net gas collisions with its container, as they are happening in all directions with equal force.
-There is a pressure disparity between the helium and oxygen, but the atmosphere would be pushing equally over the entire surface of the balloon. No net pressure would imply that lift is not possible
-Gravity is the only outside force that interacts with the spherical balloon (with no net pressure/molecular collisions). Thus, there is only a net downward force.
I'm positive that the gas density disparity between helium and our atmosphere relates to this, but how does that work on a molecular scale?
ayueh1007 said:
...but the atmosphere would be pushing equally over the entire surface of the balloon. No net pressure would imply that lift is not possible
Clearly this is not true. The higher you go the lower the pressure is. You experience this when you climb a mountain. There is more pressure on the bottom than the top. You experience this when you dive into a deep pool. This is the origin of buoyancy.
http://hyperphysics.phy-astr.gsu.edu/hbase/pbuoy.html
edit - maybe this picture is helpful too,
http://www.chemistryland.com/CHM107/AirWeBreathe/AirPressureGradientForces.jpg
Ah, thank you so much. That link really helped me.
But theoretically, in a bizarre world where there is no subtle pressure disparity between the top and bottom of a balloon, it would not rise?
Balloons rise not because of pressure but due to the difference in the weight of the helium inside the balloon envelope and the weight of air displaced by the balloon.
Ultimately, balloons rise due to Archimedes Principle.
With no pressure disparity what direction would you define as "rise"?
In a spacecraft either orbiting or far from a gravitational field a balloon would not rise, as you deduced. Gravity creates the pressure gradient which gives us buoyancy. No pressure gradient, no buoyancy.
Hey cool, it's an example of loss of accuracy when subtracting two numbers that are very nearly the same. The pressure at the top of the balloon and the bottom are very nearly the same. The balloon can do that subtraction very accurately indeed, getting the net difference in up and down forces.
Computer programmers are familiar with this subtraction thing. Floating point numbers in computers have finite accuracy. So if you have two numbers that are different by only a very small amount, and you subtract them, you lose accuracy. If you wind up doing that a few times you can get results that are pretty much of no accuracy at all.
Buoyancy is caused by a pressure gradient. If there is no pressure gradient in the displaced fluid, there will be no buoyancy.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 70 ·
  • · Replies 16 ·
  • · Replies 30 ·
