Number of quadratic residues mod N>1
  • Context: Graduate
  • Thread starter Thread starter THSMathWhiz
    Quadratic
The discussion revolves around a theorem concerning the number of quadratic residues modulo \( N > 1 \), specifically focusing on the counting of invertible squares modulo \( N \). Participants explore the theorem's proof, its implications, and the correctness of a proposed formula for calculating the number of quadratic residues based on the prime factorization of \( N \).
  • Post 1 presents a theorem with a formula for counting quadratic residues mod \( N \) based on its prime factorization, detailing a proof that includes several steps and the application of the Chinese Remainder Theorem.
  • Post 2 challenges the validity of the proposed formula by providing numerical examples from Maple that yield different results, suggesting a potential error in the original formula.
  • Post 3 clarifies a misunderstanding regarding the definition of quadratic residues, indicating that the original formula may not account for residues that are relatively prime to \( N \). A modified formula is proposed that appears to work correctly in Maple.
  • Post 4 updates the proposed formula again, indicating that it only works under certain conditions related to the number of distinct prime factors, and provides a new Maple procedure for testing the formula against random integers.
Participants express disagreement regarding the correctness of the original formula and its application. There are multiple competing views on the correct formulation and understanding of quadratic residues, with no consensus reached on a definitive formula.
Limitations include the dependence on the definitions of quadratic residues and the specific conditions under which the proposed formulas are valid. The discussion highlights unresolved mathematical steps and the need for further verification of the formulas against various cases.
THSMathWhiz
Any comments or feedback on this theorem and proof are appreciated, including improvements and past publications. Specifically, I'd like to know if someone else has come up with a formula for counting the number of invertible squares modulo N.
Definition. If [itex]x\in(\mathbb{Z}/N)^\times[/itex] satisfies [itex]x\equiv q^2\bmod N[/itex] for some [itex]q\in(\mathbb{Z}/N)^\times[/itex], then [itex]x[/itex] is a quadratic residue mod [itex]N[/itex].
Theorem. Suppose [itex]N\in\mathbb{Z}[/itex] has the prime factorization [itex]2^np_1^{l_1}p_2^{l_2}\cdots p_k^{l_k}[/itex], where the [itex]p_i[/itex]s are distinct odd primes. Then the number of quadratic residues mod [itex]N[/itex] is
[tex] \phi_2(N)=\begin{cases}\frac{N}{2^k}\prod_{i=1}^k\left(1-\frac{1}{p_i}\right),&n<4,\\\frac{N}{2^{k-n+3}}\prod_{i=1}^k\left(1-\frac{1}{p_i}\right),&n\geq4.\end{cases}[/tex]
The proof of this requires four steps.
1) [itex]\phi_2(p)=\frac{p-1}{2}[/itex] for any odd prime [itex]p[/itex].
2) [itex]\phi_2(p^k)=\frac{p-1}{2}p^{k-1}[/itex]
3) [itex]\phi_2(2^n)=\begin{cases}1,&n<4,\\2^{n-3},&n\geq4.\end{cases}[/itex]
4) If [itex](a,b)=1[/itex], then [itex]\phi_2(ab)=\phi_2(a)\cdot\phi_2(b)[/itex].
The proof of step 1 is easy. Represent [itex](\mathbb{Z}/p)^\times[/itex] as [itex]\{-\frac{p-1}{2},\dots,-2,-1,1,2,\dots,\frac{p-1}{2}\}[/itex]. Observe that this is a complete representative set containing exactly [itex]\phi(p)=p-1[/itex] elements. Square each of these elements and you get a perfectly symmetric set since the minus signs cancel. Thus there are at most [itex]\frac{p-1}{2}[/itex] residues mod [itex]p[/itex]. Since [itex]x^2\equiv1\bmod p\Longleftrightarrow x\equiv\pm1\bmod p[/itex], the homomorphism [itex]\varphi:(\mathbb{Z}/p)^\times\rightarrow(\mathbb{Z}/p)^\times[/itex] has kernel [itex]\{\pm1\bmod p\}[/itex], so the image of [itex]\varphi[/itex] has index 2 in [itex](\mathbb{Z}/p)^\times[/itex]. Thus [itex]\phi_2(p)=\frac{p-1}{2}[/itex] for any odd prime [itex]p[/itex].
Step 2 is a little more difficult. Suppose [itex]x\equiv a^2\bmod p[/itex] for some odd prime [itex]p[/itex] and [itex]a\not\equiv0\bmod p[/itex]. Then there is an integer [itex]q[/itex] such that [itex]x=a^2+qp[/itex], so [itex]x\equiv a^2+qp\bmod p^k[/itex]. Since there are [itex]p^{k-1}[/itex] choices for [itex]q[/itex] that make the congruence unique, it should follow that [itex]\phi_2(p^k)=p^{k-1}\phi_2(p)=\frac{p-1}{2}p^{k-1}[/itex].
In my opinion, step 3 is the hardest. The cases [itex]n=1,2,3[/itex] are easy to observe since only odd squares are quadratic residues modulo an even integer, and there is only one such square less than 8. For higher powers, suppose [itex]x\equiv a^2\bmod 2^n[/itex]. Then there is an integer [itex]q[/itex] such that [itex]x=a^2+2^nq[/itex], so [itex]x\equiv a^2+2^nq\bmod 2^{n+1}[/itex]. Since there are only two choices of [itex]q[/itex] that make this congruence unique, it should follow that [itex]\phi_2(2^{n+1})=2\phi_2(2^n)[/itex]. This is the inspiration for the formula above.
Finally, step 4 is the most critical and requires the Chinese Remainder Theorem. If [itex]x[/itex] is a residue mod [itex]a[/itex] and mod [itex]b[/itex] with [itex](a,b)=1[/itex], then there is a unique solution for [itex]x\bmod ab[/itex]. The number of possible solutions comes from the number of ordered pairs of residues from [itex](\mathbb{Z}/a)^\times\times(\mathbb{Z}/b)^\times[/itex], which comes out to [itex]\phi_2(a)\phi_2(b)[/itex], each of which is a residue mod [itex]ab[/itex]: if [itex]z\equiv r\bmod a\equiv s\bmod b[/itex], set [itex]x\equiv r^2\bmod a\equiv s^2\bmod b[/itex]. By the Chinese Remainder Theorem, [itex]x\equiv z^2(ca+db)[/itex] where [itex]ca+db=1[/itex]. Thus we are guaranteed at least [itex]\phi_2(a)\phi_2(b)[/itex] quadratic residues mod [itex]ab[/itex]. Now suppose [itex]y[/itex] is a residue mod [itex]ab[/itex]. Then the Chinese Remainder Theorem allows us to surmise that [itex]y[/itex] is a residue bod mod [itex]a[/itex] and mod [itex]b[/itex]. Thus we have no more than [itex]\phi_2(a)\phi_2(b)[/itex] quadratic residues mod [itex]ab[/itex]. We conclude that [itex]\phi_2(ab)=\phi_2(a)\phi_2(b)[/itex]
By combining all of these facts, we get the theorized formula for [itex]\phi_2(N)[/itex] given its factorization into prime powers. QED
Hi. I've tested your formula with Maple and it doesn't work:
phi2true:= N-> nops({seq(i^2 mod N,i=1..N-1)}) :
factorset2:= N-> selectremove(x->x[1]=2,ifactors(N)[2]) :
factorset2(2^3*7^2*11^2);
[[2, 3]], [[7, 2], [11, 2]]
phi2false:= proc(N) local f,n,p,k :
f:= factorset2(N) :
n:= `if`(f[1]=[],0,f[1,1,2]) :
p:= map(x->x[1],f[2]) :
k:= nops(p) :
return N/2^`if`(n<4,k,k-n+3)*mul(1-1/p,i=1..k)
end proc :
phi2true(2^3*7^2*11^2);
3696
phi2false(2^3*7^2*11^2);
9240
phi2true(2^4*11^3*13^2);
193076
phi2false(2^4*11^3*13^2);
1510080
May you give me some numerical example and/or tell me if my Maple algorithm is wrong?
Hi. I hope you are still interested though I had wrongly understood that you meant the number of "all" quadratic residues modulo n, i.e. the squares mod N, while you wrote "invertible squares modulo N", writing also [itex]x\in(\mathbb{Z}/N)^\times[/itex], and then you meant the quadratic residues such that are relatively prime to N: a definition of quadratic residue used by Stangl in 1996 and apparently well used today. Even MathWorld warns about this misunderstanding: http://mathworld.wolfram.com/QuadraticResidue.html .
So I must to correct my previous Maple line I used to test your formula:
phi2true:= N-> nops(select(x->igcd(x,N)=1,{seq(i^2 mod N,i=1..N-1)})) :
However there is a good news too: your formula would work if I change it a little bit. So I think there is a little mistake in your formula and I take the liberty to fix it:
[tex]\phi_2(N)=\begin{cases}\frac{N}{2^{n+2}}\prod_{i=1}^k\left(1-\frac{1}{p_i}\right),&n<4,\\\frac{N}{2^5}\prod_{i=1}^k\left(1-\frac{1}{p_i}\right),&n\geq4.\end{cases}[/tex]
In particular, I've changed the exponents of 2.
You can see that now your formula is fully working in Maple:
phi2:= proc(N) local f,n,p,k :
f:= factorset2(N) :
k:= nops(p) :
return N/2^`if`(n<4,n+2,5)*mul(1-1/p,i=1..k)
end proc :
1155
phi2(2^3*7^2*11^2);
1155
94380
phi2(2^4*11^3*13^2);
94380
UPDATE:
Sorry, yesteday I made another mistake: the formula would work only for k=2 (i.e. as in the samples I used).
This is the correct formula:
[tex]\phi_2(N)=\begin{cases}\frac{N}{2^{n+k}}\prod_{i=1}^k\left(1-\frac{1}{p_i}\right),&n<4,\\\frac{N}{2^{3+k}}\prod_{i=1}^k\left(1-\frac{1}{p_i}\right),&n\geq4.\end{cases}[/tex]
This the correct full Maple procedure:
f:= factorset2(N) :
k:= nops(p) :
return N/2^`if`(n<4,n+k,3+k)*mul(1-1/p,i=1..k)
end proc :
And these are two Maple lines to test an infinite loop of random integers until 1 000 000
do sample:= rand(10^6)() : if phi2true(sample)<>phi2(sample) then print(sample) end if end do :
  • · Replies 21 ·
  • · Replies 17 ·
