Is the curl of a field a vector or a vector density?
The discussion centers on the nature of the curl of a field, specifically whether it is a vector or a vector density. The curl, when applied to the velocity field, is defined as vorticity, represented by the equation ω^k = (ε^{ijk}/√g) ∂_i u_j. The permutation symbol ε^{ijk} is identified as a tensor density, but when defined with the factor of 1/√g, it becomes a true tensor. This leads to the conclusion that vorticity should be treated as a true vector rather than a vector density, as the transformation of the metric tensor ensures that the components represent the same physical object across different coordinate systems.
  • Understanding of tensor calculus and differential geometry
  • Familiarity with Riemannian geometry concepts
  • Knowledge of fluid dynamics, particularly vorticity and velocity fields
  • Proficiency in coordinate transformations and their implications on physical quantities
  • Study the properties of tensor densities and their transformations in Riemannian geometry
  • Learn about the implications of the determinant of the metric tensor on physical quantities
  • Explore the mathematical definition and physical interpretation of vorticity in fluid dynamics
  • Investigate the differences between true vectors and pseudovectors in physics
Physicists, mathematicians, and engineers working in fluid dynamics, as well as students studying advanced topics in tensor calculus and differential geometry.
joda80
Hi All,
I'm trying to figure out how the components of the curl transform upon changing the coordinate system. In general coordinates, the contravariant components of the curl (if applied to the velocity field; then the curl is known as vorticity) are defined as
[tex]\omega^k = \frac{\epsilon^{ijk}}{\sqrt{g}} \partial_i u _j,[/tex]
where [itex]\omega^k[/itex] is the k-th component of the vorticity, and [itex]u_i[/itex] represents the velocity field.
The permutation symbol, [tex]\epsilon^{ijk} = \mathbf{g}^i \cdot \mathbf{g}^j \times \mathbf{g}^k,[/tex] is a tensor density. But if we define the permutation symbol as [itex]\frac{\epsilon^{ijk}}{\sqrt{g}}[/itex], it is an honest tensor. If we use this tensor in the definition of the curl, as done above, shouldn't the vorticity be a true vector as well (rather than a vector density)? I guess I'm not really sure how to show that, however. Simply applying the transformation matrix to the free index doesn't seem give the right answer, because I'd ignore the contracted indices (i.e., the epsilon tensor and the determinant of the metric tensor also need to be transformed, right?). Perhaps someone can point me in the right direction. (I'm confused because I keep reading that the curl is a vector density.)
There is a related "philosphical" question: I used to think that only true vectors (or tensors/spinors in general) represent physically meaningful quantities. If an object doesn't transform like a tensor, doesn't that mean that it isn't independent of the coordinate bases?
The local rotation of a fluid is something that exists independently of our choice of a coordinate basis, so shouldn't the vorticity be a true vector? Or am I misinterpreting what a vector density really is. Perhaps the additional factor that apparently appears during the transformation is *required* to ensure that the components indeed represent the same object in every coordinate system?
Thanks for helping out!
Johannes
I won't address the <philosophical> issue, just state that the sqrt of det of the metric tensor does just that: in a riemannian geometry converts the vorticity into a vector, rather than pseudovector. The <curl>'s general definition should be ammended with the 1/sqrt.
Thanks! I think there's an error in the way I defined the permutation symbol. It should be {+1, -1, 0}. If defined in terms of the basis vectors as done above, we actually wouldn't need the sqrt-factor in the definition of the curl. But my main confusion has been settled...
  • · Replies 16 ·
