Points relative to vectors. And Eq of line. Vectors
The discussion revolves around finding coordinates relative to unit vectors and determining the parametric vector equation of a line defined by two points in three-dimensional space. The original poster presents two questions involving vector operations and representations.
  • The original poster attempts to find coordinates α, β, and γ by using the dot product with given unit vectors. Some participants question the definitions and roles of the unit vectors u, p, and q, seeking clarification on their properties. Others suggest reconsidering the notation used for constants in the linear combination.
Participants are actively engaging with the problem, with some providing their calculations and interpretations. There is a mix of attempts to clarify the setup and explore the relationships between the vectors. No explicit consensus has been reached, but there is a productive exchange of ideas regarding the vector representations.
There is some confusion regarding the definitions of the unit vectors and the notation used for the constants in the linear combination. The original poster has requested guidance without direct answers, indicating a desire to explore the problem further.
Jbreezy
Find the coordinates of α, β, and γ rel. to u, p, q (unit vectors) of x = 1/9( 2i + 62j - 11k )(
(Note there orthogonal to each other)
Question 2 : The position vectors of two points A, B has position vectors a = < 2, 1, 7> and
b = <1, 4,-1>
Find the parametric vector eq of the line AB using lambda as parameter.
For the first question I just did the dot product of x with each unit vector.
I ended up with σ = 2 , β = 3 , γ = 6
What do you think?
For the next question please don't give me an answer give me a question to direct my though if it is incorrect. Thanks.
So I said x = a + λb
Where b is a unit vector. Is this proper? I didn't want to expand it and write the vectors it will look a mess.
I have the unit vector b = < 1/ (3sqrt 3), 4/ (3 sqrt 3), -1/ (3sqrt 3)>
I think this is proper.
b = <1, 4,-1>
What do you think?
What are u, p, and q? All you said was that they are unit vectors that are orthogonal to each other.
Didn't you post this as a separate question in your other thread?
Mod note: Edited to properly show what was quoted.
What do you mean what are they? I don't understand.
Yeah I posted this first then I thought not to clump so just ignore the second question. Thanks.Sorry they are
q = < 4/9 , 7/9 , -4/9 >
u = < 1/9, 4/9 , 8/9 >
p = < -8/9, 4/9 , -1/ 9>
The problem is to write x = <2/9, 62/9, -11/9> as a linear combination of u, p, and q.
In other words, you want to find constants a, b, and c (didn't see the point in using Greek letters) so that
x = au + bp + cq
Yeah and I got σ = 2 , β = 3 , γ = 6, so x = 2u + 3p + 6q
assuming that I kept that in the right order. and your a = alpha , b = beta, c = gamma.
I just had greek because the problem used it.
This letter -- σ -- is sigma (lower case). This one is alpha - α.
