CHECK Conics question on general form of conic equation
The discussion revolves around identifying the type of conic section represented by the equation 6x^2 + 2y^2 - 9x + 14y - 68 = 0, specifically focusing on whether it is an ellipse or a circle, and the conditions under which it can be transformed into a circle. Participants also explore the implications of interchanging parameters in the context of the conic's orientation.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • The original poster attempts to classify the conic based on the values of parameters a and b, questioning how these affect the shape and orientation of the conic. Some participants seek clarification on the definitions of a and b in the context of the general form of a conic equation. Others discuss the implications of interchanging these parameters on the orientation of the ellipse.
Participants have provided feedback on the original poster's reasoning, with some affirming the correctness of their answers while questioning the interpretation of horizontal and vertical ellipses. There is an ongoing exploration of how to determine the orientation of the ellipse based on the general form of the equation.
There is a mention of the need for understanding semi-major and semi-minor axes, as well as the conditions under which the ellipse is classified as vertical or horizontal. Some participants express uncertainty about these terms and their implications in the context of the problem.
aisha
[tex]6x^2 + 2y^2 - 9x +14y -68=0[/tex]
a) which conic is represented by the equation why?
I think the ellipse is represented by the equation because a does not = b and ab >0
b)What value of "a" would transform the conic into a circle?
I think when a=b and ab>0 then the conic will be transformed into a circle therefore the value of "a" will be 2 in order for the conic to transform into a circle.
c)What value of "b" would transform the original conic into a circle?
I think when b=a and ab>0 then the conic will be transformed into a circle. Therefore the value of "b" to transform the original conic into a circle would be 6.
d) What change would take place if the value of "a" and "b" were interchanged?
I think if the values of "a" and "b" were interchanged then the ellipse would change from being a horizontal ellipse to a vertical ellipse.
Can some1 please help me out and tell me if any of my answers are wrong? :redface:
What are you calling [itex]a[/itex] and what are you calling [itex]b[/itex]?
Well when in general form a conic's equation is in the form
[tex]ax^2 + by^2 + 2gx + 2fy + c = 0[/tex] general form
so I am using the first two terms in the given equation as a and b
All of your answers are okay, except for the last one. I don't know what you mean by a horizontal or vertical ellipse. As given, the semi-major axis of the ellipse is vertical, so [itex]a \leftrightarrow b[/itex] makes the semi-major axis horizontal.
horizontal ellipse means that the major axis is horizontal and
vertical ellipse means that the major axis is vertical.
I don't understand or know the semi-terms yet is my answer correct?
in that case it's vertical to start and horizontal when you switch them.
yeah that's about right Data
In one of my other posts someone wrote
If the denominator attached to the x is less than that of the y then it will be vertical, (as there is less of a distance between the x intercepts that the y).
The semi-major axis will be the root of the largests denominator
The semi-minor axis will be the root of the smallest denominator
The coordinates of the center will be (h,k) for and elispse in the form (just a simple translation)
but this was if the equation was in standard form.
Can you explain to me how you know if the ellipse is vertical or horizontal looking at the general form of the equation?
Assume [itex]ab>0[/itex]. Then
[tex]a>b[/tex]
implies that it's vertical.
Remember when you complete the squares you'll get something in the form
[tex]a(x-\gamma)^2 + b(y-\alpha)^2 = \lambda[/tex]
so dividing out [itex]ab[/itex] gives
[tex]\frac{(x-\gamma)^2}{b} + \frac{(y-\alpha)^2}{a} = \frac{\lambda}{ab}[/tex]
and thus using the rule you posted above, the ellipse is vertical if [itex]a>b[/itex] and horizontal if [itex]b>a[/itex] (and a circle if [itex]a=b[/itex]).
25K
  • · Replies 18 ·
