Solving for Oscillation with Given Parameters
  • Thread starter Thread starter skrat
    Oscillation
The discussion focuses on solving the differential equation ##\ddot{x}+\Omega^{2} x=D+\frac{C}{2}+Ecos\omega t+\frac{C}{2}cos2\omega t## using the proposed solution form ##x=\alpha sin\omega t+\beta cos\omega t##. The user derived four separate equations from substituting this form into the original equation, leading to conclusions about the constants C and D being zero. The user seeks clarification on solving for the parameter β without dividing by it, indicating uncertainty in handling potential zero values.
  • Understanding of second-order differential equations
  • Familiarity with trigonometric identities and functions
  • Knowledge of oscillatory motion and harmonic analysis
  • Experience with solving linear equations
  • Study methods for solving second-order linear differential equations
  • Learn about the use of undetermined coefficients in differential equations
  • Research the implications of zero coefficients in linear equations
  • Explore the concept of resonance in oscillatory systems
Students and educators in physics and engineering, particularly those focusing on oscillatory systems and differential equations.
skrat
Solve: ##\ddot{x}+\Omega^{2} x=D+\frac{C}{2}+Ecos\omega t+\frac{C}{2}cos2\omega t##
I got a hint to use ##x=\alpha sin\omega t+\beta cos\omega t## so ##\ddot{x}=-\alpha ^{2}\omega ^{2}sin\omega t-\beta ^{2}\omega ^{2}cos\omega t## in the equation above than:
##(-\alpha ^{2}\omega ^{2}sin\omega t-\beta ^{2}\omega ^{2}cos\omega t)+\Omega^{2}x=\alpha sin\omega t+\beta cos\omega t=D+\frac{C}{2}+Ecos\omega t+\frac{C}{2}cos2\omega t##
Which gives me 4 separate equations depending on ##sin\omega t##, ##cos\omega t##, ##cos2\omega t## and constant:
first: ##-\alpha ^{2}\omega ^{2}+\Omega ^{2}\alpha=0##
second: ##-\beta ^{2}\omega ^{2}+\Omega ^{2}\beta =E##
third: ##\frac{C}{2}=0##
fourth: ##D+\frac{C}{2}=0##
Forth and third together say that ##D=0## and ##C=0##
First says that:
##\alpha ^{2}\omega ^{2}=\Omega ^{2}\alpha##
##\alpha =(\frac{\Omega }{\omega })^{2}##
But for second I am not sure, whether I can divide it with ##\beta## (probably not since it could be equal to 0) or how do I solve it?
PLEASE HELP
BTW, if everything is completely wrong and this is not how usually this kind of equations are solved, please let me know.
C and D are given, so if you deduce values for them you have gone wrong. Seems to me you need more flexibility in your proposed solution, probably terms involving sin and cos of 2ωt.
  • · Replies 23 ·
