Matlab code for solving and plotting function x'(t) = 1 + t*sin(t*x)
The original poster is attempting to solve and plot the differential equation x'(t) = 1 + t*sin(t*x) with the initial condition x(0) = 0 and a final time of t_final = 1. The goal is to compare the exact solution with approximations obtained through Euler's and Improved Euler's methods.
  • Exploratory, Assumption checking, Mixed
  • Participants discuss the challenges of solving the equation algebraically, noting that both Wolfram Alpha and MATLAB indicate a lack of an algebraic solution. There is mention of using numerical solvers, with one participant expressing uncertainty about which solver to use and another suggesting a specific solver based on familiarity.
The discussion is ongoing, with participants exploring numerical methods as a viable approach to the problem. Guidance has been provided regarding the use of a specific numerical solver, though there is no consensus on the best method or a complete solution yet.
Participants are navigating the limitations of algebraic solutions and the appropriateness of numerical methods for this particular problem. There is an acknowledgment of the varying techniques available for solving differential equations in MATLAB.
bdoherty1994
I am trying to solve and plot the function, x'(t) = 1 + t*sin(t*x) where x(0) = 0 and t_final = 1, in order to compare this exact solution to the approximations of Euler's and Improved Euler's Method. Can anyone help me with the code in order to solve this problem, and then plot it, using Matlab?
I have tried to use dsolve() only to come up with an error.
wolfram alpha can't solve it and MATLAB tells me it can't find a solution either so I'm guessing you can't solve it algebraically. If you use a numerical solver on MATLAB the solution you get will be so close to the correct solution that if you knew the solution you wouldn't be able to tell the difference, so I'd just use that
Thank you for your help! Which numerical solver would you recommend?
I don't really understand the differences between them (they are designed to solve much harder problems than this one using varying techniques). I typically use this one
http://www.mathworks.com/help/matlab/ref/ode15s.html
but only because it's the one that I have seen used in examples and thus is the one I remember when I have to do something like this. Someone else could better explain what the advantages/disadvantages of each are perhaps, but it doesn't matter to this problem
