Is there a way of measuring reflectance vs absorbance
This discussion focuses on measuring the effectiveness of EMI shielding materials against electromagnetic waves, both qualitatively and quantitatively in decibels (dB). Key methods include using a power meter sensitive to the specific electromagnetic frequency range and conducting tests with an enclosure to isolate the material's shielding capabilities. The complexity of measuring reflectance is highlighted, as it requires consideration of both specular and diffuse reflections, depending on the wavelength of interest.
  • Understanding of EMI shielding principles
  • Familiarity with power meter operation
  • Knowledge of electromagnetic wave properties
  • Experience with enclosure testing methods
  • Research the specifications and operation of power meters for electromagnetic wave measurement
  • Explore methods for conducting EMI shielding effectiveness tests using enclosures
  • Learn about the principles of reflectance and how to measure it in various materials
  • Investigate the impact of different wavelengths on EMI shielding performance
Engineers, researchers, and technicians involved in EMI shielding effectiveness testing and material analysis will benefit from this discussion.
PolyOneTechie
I am looking at EMI Shielding effectiveness testing and I would like to measure how a material is shielding Electromagnetic waves, qualitatively. Is there a way to measure how a material is shielding qualitatively and quantitatively (in dB)?
Science news on Phys.org
Er... hum. Get a power meter sensitive to the range of EM wave that you're interested in, and put it on the other side of the EM source and measure?
Zz.
What is the form of this "shielding"? For good shielding, you need an enclosure, which makes it relatively easy to test - by putting a measuring receiver inside (self powered, preferably, to reduce the number of ways the unwanted signal can get in) and measuring with and without the box. Alternatively, you can put a (self-powered) source in the box.
Measuring the reflectance is much harder because you may need to look in all directions as there may be specular or diffuse reflection.
This all depends upon the sort of wavelength you're dealing with, of course. Give us a clue?
