[Matlab] Transform generated table to equation for for loop usage
The discussion revolves around optimizing MATLAB code for processing a matrix by transforming a lookup table into direct equations for indexing. Participants explore the implications of using raster segments from a binary image matrix and seek to improve memory efficiency while maintaining functionality.
  • The original poster describes a need to replace a lookup table with equations to determine the center point location in a matrix A based on raster segments.
  • Some participants suggest vectorizing operations to reduce memory usage and improve performance, noting that nested for loops can be inefficient.
  • One participant explains how the im2col() function organizes the 3x3 matrices and proposes reshaping the output to align with the original matrix A.
  • Another participant shares their approach of using a neural network within the nested loops to process each raster segment, emphasizing the need for efficient memory management.
  • A later reply indicates a realization that the lookup table can be replaced with direct calculations using the current row and column indices from the loops.
Participants express different strategies for handling the raster segments and optimizing memory usage. While some agree on the benefits of avoiding large matrices, there is no consensus on the best approach, as various methods are proposed and explored.
Limitations include the potential complexity of the neural network integration and the specific conditions under which the transformations are applied. The discussion does not resolve the optimal method for all scenarios.
Readers interested in MATLAB programming, image processing, and optimization techniques for handling large datasets may find this discussion relevant.
roldy
I have posted a question on here before regarding the generation of a number sequence. I followed up that question with an answer. However, as I have developed my code more I need to use an equation instead of a lookup table.
Note: I'm using MATLAB
Given a matrix A of size r x c where r >= 3, c >= 3 I need to map the center point of a 3 x 3 raster segment to a point in A. The raster segments go from left to right, top to bottom. For example, if
Code:
A = [0 1 1 0 1 0 1 0 1;...
      0 0 1 0 0 1 1 0 1;...
      1 0 1 1 0 1 0 1 0;...
      1 1 1 1 1 1 1 1 1];...
The location of (2,2) in each raster segment can be found as follows.
Code:
%raster binary image matrix into 3x3 segments
M = im2col(FP, [3,3],'sliding');
[ri ci] = size(A);
[rM cM] = size(M);
%Generate table of locations in binary image matrix for center point (2,2) of segment matrices
rownums = repmat([2:ri-1],cM/(ri-2),1);
rownums = rownums(:);
colnums = repmat([2:ci-1]',1,cM/(ci-2));
colnums = colnums(:);
locations = [rownums,colnums]
I only need matrix M to find what rM and cM are. Instead of using the im2col() function, I can use the equations below. cM is the number of total raster segments
Code:
rM = 9;
cM = (ci-2)*(ri-2);
I do some matrix operations for each raster segment using a for loop
Code:
n = 1;
k = 1;
for row = 1:ri-2
	for col = 1:ci-2
           %some operations
                if %condition is met
                    %transform center point location in raster segment
                    %to corresponding location in matrix A
                    Iloc(n,:) = locations(k,:);
                    n = n+1;
                end
            else   %if condition is not met, increment segment counter k and continue
                    %in for loop to next segment
                k = k+1;
                continue
            end
        k = k+1;
	end
end
I would like to replace this line of code
Code:
with equations for the row and column location in A instead of looking up in the table for these locations. The reason for this is that if I have a matrix A of size 274 x 234, I would have 63104 raster segments. This means that my location table matrix would be 63104 x 2. This takes up a lot of memory with the other stuff that I am doing. I know it's possible to come up with some equation that's dependent on the value of row, col, and k. It seems that every (ci-2) kth value, the row in A increments by one. For every different row value, the column values go from 2:(ci-1).
Question is how do I activate the row increment and column range for every (ci-2) kth value?
My first reaction is that instead of summing over rows and columns you can probably vectorize the operation to save a lot of memory. Nested for loops are really expensive here, so it's worth looking in to.
Also, im2col() puts the 3x3 matrices in the columns of M, so that M(5,:) is the row vector of the (2,2) element in each 3x3 matrix.
Then
m = reshape(M(5,:),272,232)
turns that vector of centers into the same form as it is in A, and is equivalent to A with the edge values shaved off, A(2:end-1,2:end-1).
Each element in this matrix corresponds to the center of one of the 3x3 matrices, and the indices are each padded by 1, i.e. the (1,1) element in m is the (2,2) element in A, and so on.
kreil, within the nested for loops I submit the raster segment to a trained neural network to see if there is a match (part of the project criteria). The simulation of the neural network goes in place of "some operations". If I return a match, then I proceed to get the location from the table that's the if logic statement. Once I get all the locations, I use a logical mask to color a pixel red at transformed locations. There are two ways that I can go about this. The first method I tried was to just use one for loop that cycles through each raster segment in M. This is originally why I needed the table for the locations. The reason why I'm leaning towards the nested for loop is because I don't have to store anything, such as the huge M matrix or the table locations if I can transform the table calculations to equations. Any thoughts on this?
I've attached the necessary files to run this program. The main program is locateBifurcation. I've included a fingerprint image in case you wanted to test this on a full fingerprint instead of the small test logic matrix I created. The image must first get passed into imread() then into preprocess(I) to convert to a binary matrix.
I think I figure this out. Simple solution actually, don't know why I didn't think of this before. I just replaced the table look up with the row and col value added by one from the for loops.
Code:
   Iloc(n,:) = [row+1,col+1];
   %Iloc(n,:) = locations(k,:);
   n = n+1;
end
11K
  • · Replies 41 ·
11K
