A Problem with Two Current-Carrying Wires
  • Context: Undergrad
  • Thread starter Thread starter Radek Vavra
    Wires
The discussion revolves around the interactions between two current-carrying wires, specifically focusing on the forces involved and the implications of different reference frames. Participants explore concepts related to magnetic fields, electrostatic forces, and practical issues arising from wire configurations.
  • One participant questions the existence of a magnetic field and force between two wires if the electrons in both wires are moving at the same speed, suggesting that the relative velocity would be zero.
  • Another participant asserts that there is indeed a magnetic field and force in the lab frame, while noting that in the electrons' frame, the situation differs due to the movement of protons in the opposite direction.
  • A third participant adds that in the electrons' rest frame, the charge densities of positive and negative charges differ, leading to a net electrostatic force in addition to the magnetic force between the protons.
  • Another point raised discusses practical issues where thin gauge insulated wires can inadvertently act as antennas, potentially causing frequency problems in certain applications.
Participants present multiple competing views regarding the forces at play between the wires and the implications of different reference frames. The discussion remains unresolved, with no consensus reached on the nature of the forces involved.
Participants highlight the complexity of the interactions, including the dependence on reference frames and the differences in charge densities, but do not resolve these aspects.
Radek Vavra
We all know that there is a force between them. But I wonder... if electrons in both wires are moving with the same speed the relative velocity between the electrons in wire A and B equals zero - but then there would be no magnetic field and no force. Could you help me with this?
There is a magnetic field and a force in the lab frame. In the frame of the electrons, there is not - but then you have protons moving in the opposite direction.
Also, in the electrons' rest frame, the positive and negative charge densities are different, so there is a net electrostatic force in addition to the magnetic force between the protons.
They also discovered that a pair of wires of thin gauge (insulated) will accidentally become an antenna and cause frequency problems in certin applications.
  • · Replies 61 ·
  • Sticky
  • · Replies 0 ·
