Describing anEquilibrium Solution which is neither Stable or unstable?
  • Thread starter Thread starter raaznar
    Stable
The discussion centers on the stability of equilibrium solutions for the differential equation dy/dx = cos^2(y) within the interval 0 <= y <= 2π. The equilibrium solutions identified are y = π/2 and y = 3π/2. The behavior of solutions near these equilibria indicates that they neither attract nor repel nearby trajectories, leading to the conclusion that these points act as "centers," where periodic solutions circulate around them without converging or diverging.
  • Understanding of differential equations, specifically first-order equations.
  • Familiarity with equilibrium solutions and their stability analysis.
  • Knowledge of periodic functions and their graphical representations.
  • Basic graphing skills to visualize y(x) behavior in relation to equilibrium points.
  • Study the concept of "centers" in dynamical systems and their implications for stability.
  • Explore the method of phase portraits to visualize the behavior of solutions around equilibrium points.
  • Learn about Lyapunov stability and how it applies to equilibrium solutions.
  • Investigate the role of periodic solutions in nonlinear differential equations.
Mathematics students, particularly those studying differential equations, educators teaching stability analysis, and researchers interested in dynamical systems and their behaviors.
raaznar
Discuss the stability of the equilibrium solutions
dy/dx = cos^2(y) between 0<=y<=2pi
y(0)=0
y(0)=pi/2
y(0)=pi
Found the equilibrium solutions to be pi/2 and 3pi/2.
Rough graphed y(x) which was a y vs x graph with horizontal lines (Eq Solu) at pi/2 and 3pi/2.
Then added the curves y(0)=0 and y(0)=pi which are graphs approaching Eq Sols pi and 3pi/2 respectively.
Now, I'm not sure how to describe the equilibrium solutions. The graph is neither stable or unstable but just keeps repeating in the given domain. How would I describe this type of behaviour? Thanks
y(0)=0
y(0)=pi/2
y(0)=pi
Repeating is not the important feature, it's whether a solution starting near your equilibrium solution will flow into or out of the equilibrium solution. If you start with an initial condition a little below y=pi/2, what does it do? What about a little above?
If, as you appear to be saying, the solutions near the equilibrium solution tend neither toward it nor away from it but circulate around it, then the equilibrium solution is a "center": there are periodic solutions in its vicinity.
