Stuck on cryptology problem(vigenere cipher)
  • Thread starter Thread starter FYAD
    Cryptology Stuck
The discussion centers on decrypting a Vigenère cipher with the ciphertext provided. The user employs the Kasiski test and the Friedman test to estimate the key length, concluding that it is likely 10, despite initial suggestions of 4. Frequency analysis is conducted on subsequences derived from the ciphertext, but results yield inconsistent mappings. The user contemplates a brute force approach to decipher the text, considering the computational complexity of 26^10 possible combinations for the keyword.
  • Understanding of Vigenère cipher mechanics
  • Familiarity with Kasiski examination and Friedman test for key length estimation
  • Knowledge of frequency analysis techniques in cryptography
  • Basic programming skills for implementing brute force algorithms
  • Implement frequency analysis on the entire ciphertext instead of individual columns
  • Explore patterns in the ciphertext for repeated words or phrases
  • Consult cryptography literature for advanced techniques in Vigenère cipher decryption
  • Develop a brute force program to automate keyword testing for the Vigenère cipher
Cryptography students, hobbyists interested in cipher decryption, and programmers looking to enhance their skills in algorithm development and frequency analysis.
FYAD
I was assigned to decrypt this cipher text:
EWPW DRAPO MGTGT EXVAH RPSWI LSFUN RZVSE FOIWJ
NYOU MHSER EFBMB VANHA LOOXI VPBIF FIFMA BFGRH
GARE TLKLF NZQXQ DWGKP UWNWQ QFRZL VROOP UGBQQ
HVKS CDOPW LSGTE JMFSE MLZMD TNDED VVGRO UUMLV
NLHA KWASO ITAPR DTBBG CHDSH TNSFM NGWMF CASWM
WGKD RWJRN UNDVV SFFAE TAGUF HLAUC AETLB MHVAN
WJHU QUQQL SQETD BWGBR APMJW PM
the kasiski test is of no real help; the frequencies are to close together.
highest frequencies of 2 and 3 letter substrings
(higher substrings have almost no discrepancies of frequency):
et: 0.01544402 (132,12,20)
aet: 0.007751938 = 12
kasiski yields 4 as gcd, which suggests 4 as the keylength.
Index of Coincidence is 0.04110484 ; this value is much closer to 0.038 than 0.065, which suggests that the encipherment scheme is polyalphabetic(confirmed by professor to be vigenere).
using the friedman test yields:
(.027*260)/((259*.04110484)-(.038*260+.065)) = 10.01
suggesting that the keylength is 10, which is definitely a better guess than 4(our professor supplied the hint that the keyword was of length 7,8,9 or 10).
going on the guess that the keylength is 10, i split the cipher text into 10 subsequences:
egpzybofrxwosedokdtcwflhqg
wtsvomxmeqqpcjtuwtnajfavqb
pgwsubiatdqudmnuabssraualr
wtiemvvblwfgofdmsbfwnecnsa
delfhapfkgrbpselogmmutawqp
rxsosnbglkzqwedvicnwnaejem
avfiehirfplqlmvnthggdgthtj
pauwrafhnuvhslvladwkvuludw
ohnjelfgzwrvgzghpsmdvfbqbp
mrrnfoiaqnoktmrarhfrshmuwm
with respective ic's of:
0.02461538
0.03384615
0.05538461
0.03692308
0.02769231
0.02461538
0.04
0.06153846
0.02769231
0.06461538
which isn't very much help, as only 3 of the 10 are closer to .065 than .038. supposing that the keylength guess of 10 was incorrect, i split the message into subsequences of 7,8 and 9, and calculated their ic's only to be equally disappointed in the results.
now, going by the results of the friedman test, i stick with a keylength of 10 and use frequency analysis on the results of the split, starting with column ten as its ic was closest to .065 than the others, and i figured it would be easiest.
this netted frequency results of:
r: 0.1923077
m: 0.1538462
a: 0.07692308
f: 0.07692308
h: 0.07692308
n: 0.07692308
o: 0.07692308
i: 0.03846154
k: 0.03846154
q: 0.03846154
s: 0.03846154
t: 0.03846154
u: 0.03846154
w: 0.03846154
suggesting that e mapped to r, and t mapped to m. however, this implies a shift of 13 and 19 respectively, which is inconsistent. i play around with the most commonly used letters(e,t,a,i,n), and i find a shift that looks possible:4.
n to r = 4
i to m = 4
e to a = 4
b to f = 4
d to h = 4
j to n = 4
k to o = 4
a to w = 4
so e mapps to a and presumably the last letter of the keyword is w. trying similar methods on the other subsequences doesn't yield any satisfactory results, and I'm stuck. I've tried asking other people in my class, but none have gotten any farther than i! my professor said this was a somewhat difficult problem and I'm getting fustrated. I'm thinking about writing a brute force program; try every possible combination of ten characters for the keyword - ignoring keywords with repeated letters - and using those keywords to decipher the message and searching the output for the most common digraphs and trigraphs. I'm not exactly sure how feasible this is (26^10 possible combinations?) but I'm going crazy here.
It seems like you have made a lot of progress in your attempts to decrypt the cipher text, but you have hit a roadblock. It can be frustrating when you have tried different methods and still can't find the solution. I would suggest taking a step back and looking at the problem from a different perspective. Have you tried looking for patterns in the cipher text? Are there any repeated words or phrases that could give you a clue about the keyword? Also, have you considered using a different approach such as frequency analysis on the whole text instead of just individual columns? It may also be helpful to consult with your professor again and see if they can provide any additional hints or tips. And, while a brute force program may be an option, it may be time-consuming and not guaranteed to give you the correct keyword. Keep trying different methods and don't give up. Sometimes the solution comes when you least expect it. Good luck!
11K
