Conservation of Momentum with Varying Mass
The discussion focuses on the conservation of momentum in a system where a boat with mass M collects balls of mass m thrown at it at a continuous rate of σ kg/s. The key equation used is Δmu + MV = (Δm + M)(V + ΔV), which describes the momentum change during inelastic collisions. Participants confirm that since no external forces act on the system, linear momentum is conserved, allowing for the calculation of the boat's velocity and position over time.
  • Understanding of conservation of momentum principles
  • Familiarity with inelastic collisions
  • Knowledge of differential equations
  • Basic concepts of mass flow rates
  • Study the derivation of the rocket equation in varying mass systems
  • Learn about inelastic collision dynamics in physics
  • Explore differential equations related to motion with changing mass
  • Investigate the effects of external forces on momentum conservation
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in understanding momentum conservation in systems with varying mass.
godman1402
A boat with mass M is at rest. Balls are thrown at the back of the boat, where each ball has mass of m, and the balls are being thrown with the mass rate of σ kg/s (the rate is continuous). The balls are being collected inside the boat (inelastic collision). Find velocity and position of the boat as a function of time.
I thought I could use the rocket equation for this, but I had trouble figuring it out because I wasn't sure if I can assume ƩF = 0.
Rockets don't usually scoop up their own exhaust products. Once the exhaust mass leaves the rocket, it is assumed to be lost permanently.
Yes you can go ahead and use the conservation, there is no outer force acting on the system. The Boat is not fixed by some outer force so we can translate it in space and get the same dynamics meaning linear momentum is conserved (we assume the effect of water on the boat negligible).
  • · Replies 30 ·
  • · Replies 53 ·
