Question on generalized inner product in tensor analysis
The discussion revolves around the concept of the generalized inner product in tensor analysis, particularly in the context of metric tensors and their application in different coordinate systems. Participants explore the implications of using the metric tensor to define inner products, especially in curvilinear coordinates, and the challenges that arise from position dependence and coordinate representation.
  • One participant expresses confusion regarding the ambiguity of the inner product formula involving the metric tensor, particularly in relation to the coordinates used.
  • Another participant clarifies that the metric tensor is position-dependent but is a coordinate-independent object, emphasizing the need to specify the chart when using the metric for calculations.
  • A participant acknowledges the importance of specifying the location of vectors when using the metric tensor, referencing a common mistake in understanding inner products in polar coordinates.
  • Further discussion raises a question about whether a technique involving parallel transport of vectors to a common location works only in flat manifolds.
  • Concerns are raised about the transition from Euclidean vector concepts to manifold theory, with a participant questioning how to reinterpret position vectors in this new context.
  • Another participant suggests performing calculations by pulling back the standard inner product from Euclidean space to better understand the metric on manifolds.
Participants generally agree on the need to specify the position of vectors when using the metric tensor, but there remains uncertainty regarding the applicability of certain techniques across different types of manifolds. The discussion includes multiple competing views on how to approach the understanding of inner products in the context of manifolds.
Limitations include the dependence on specific coordinate systems and the unresolved nature of how to effectively transition from Euclidean vector concepts to manifold theory without losing clarity.
mnb96
Hello,
some time ago I read that if we know the metric tensor [itex]g_{ij}[/itex] associated with a change of coordinates [itex]\phi[/itex], it is possible to calculate the (Euclidean?) inner product in a way that is invariant to the parametrization. Essentially the inner product was defined in terms of the metric tensor as: [tex]g_{ij}a^i b^j[/tex] using Einstein notation (see here).
I understand Einstein summation convention, but the problem that I have here is that this formula looks totally ambiguous to me. In fact, the article speaks about curvilinear coordinates, thus the metric tensor [itex]g_{ij}[/itex] is inevitably position-dependent. When I see [itex]g_{ij}[/itex] I interpret it as [itex]g_{ij}(u_1,\ldots,u_n)=g_{ij}(\mathbf{u})[/itex]. The formula above does not say *what* coordinates we have to plug into u.
I would really like to see how someone uses the formula above to calculate the inner product between two vectors in ℝ2 expressed in polar coordinates: [itex](r_1,\theta_1)=(1,0)[/itex] and [itex](r_2, \theta_2)=(1,\frac{\pi}{2})[/itex]. The result should be 0.
The metric tensor assigns an inner product ##g_p:T_pM\times T_pM\rightarrow \mathbb{R}## for each ##p\in M## and varies smoothly from point to point so in this sense yes it is position dependent. It is a coordinate independent object and you should think of it as such i.e. ##g_{p}(u,v), u,v\in T_pM## is not dependent on what chart you choose containing ##p##.
What you should realize is that when you write ##g_{ij}##, it is the coordinate representation of the metric tensor ##g## with respect to some smooth chart hence it is already determined what coordinates you are to be using for your computation. To be more precise, if ##p\in M## and ##(U,\varphi)## is a chart containing ##p## then the coordinate representation of ##g_{p}## is given by ##g_{ij} = g_p(\frac{\partial }{\partial x^{i}}|_p, \frac{\partial }{\partial x^{j}}|_p)##. If ##(V,\phi)## is another chart containing ##p## then we get another coordinate representation ##g'_{ij} = g_p(\frac{\partial }{\partial x'^{i}}|_p,\frac{\partial }{\partial x'^{j}}|_p)## and we know that under the transition map, these two representations are related by ##g'_{ij} = \frac{\partial x^{k}}{\partial x'^{i}}\frac{\partial x^{l}}{\partial x'^{j}}g_{kl}##.
As for the computation you were interested in, this is a mistake my special relativity professor loved to bring up. In polar coordinates, you must specify where the vectors are located, not just their components in the polar representation! You cannot use the metric tensor without specifying the positions of the vectors. I had originally written up the issue but there is a whole thread regarding this commonly made mistake: https://www.physicsforums.com/showthread.php?t=621707
Hi WannabeNewton!
Thanks, your explanation was very clear. Basically the metric defines (smoothly) a field of local inner products that are different at each location. Thus only vectors belonging to the same tangent space (i.e. originating from the same location) can be fed to the local inner product operator. This is clear.
I understand now what went wrong in example, but there is still something that bothers me:
1) In the old thread that you mentioned, in one of the last posts, the author gordon831 seems to have addressed the problem and he/she claimed to have successfully obtained the correct result with an example analogous to the one I made.
It seems to me, that gordon831 essentially took one of the two vectors and he/she performed a parallel transport to the location of the other vector, then he/she re-expressed the transported vector as linear combination of the local frame of the other vector and got a correct result.
Does this trick always (and only!) work when the manifold is flat?
2) These sort of misunderstandings mostly come from the fact that when working with ordinary vector spaces (and Euclidean vectors) students are always taught to visualize vectors as entities "originating" from 0 and pointing to a specific location. However when teachers and authors of books start speak about manifolds, they don't clearly say what happens to the old concept of position vector. They seem to silently forget about it and start talking about vector fields! This is painfully confusing for a beginner.
Should I perhaps start performing the mental exercise of reinterpreting the Euclidean space as a manifold whose tangent spaces at each location are constant and having metric equal to the identity matrix? If the answer is yes, then how do you interpret the old position vectors? You interpret them as vectors in this manifold that are placed at arbitrary locations? or strictly at the origin?
All gordon did was express the vectors in terms of the frame at an arbitrary but common point for both vectors; it works because we are just converting from cartesian to polar in flat space so yeah.
As for your second question, I really don't know if that mental exercise will be helpful or not. My first exposure to thinking about these things came from learning general relativity so I can't say from experience if that mental exercise will actually be useful because I never tried it.
Hi, mnb96:
Besides WBN ideas, maybe you can do some "down-and-dirty" calculations in the case
of an m-manifold M embedded in R^n by pulling back the standard inner-product in R^m
(seen/considered as a 2-tensor) by the individual chart maps. Maybe start with low-dimensional
cases, like pulling back the inner-product of R^1 to a curve --single chart; don't take anything
too crazy for a start. Maybe it may also help to see the argument of how any smooth manifold
can be given a Riemannian metric by pulling back the inner-product . Here you use a lot of
the issues that I think you're interested in.
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 37 ·
