Is Changing Radius Constant Equal to a Constant Rate of Change in Area?
The discussion revolves around the relationship between the rate of change of the radius of a circle and the rate of change of its area. Participants are exploring whether a constant rate of change in radius implies a constant rate of change in area.
  • Conceptual clarification, Mathematical reasoning
  • Participants examine the mathematical relationship between the radius and area of a circle, questioning if a constant rate of change in radius leads to a constant rate of change in area. They discuss the dependency of the area change on the radius at a given time.
There is a consensus among some participants that the rate of change of area is not constant, even if the rate of change of radius is constant. The discussion includes clarifications and confirmations of understanding, with participants reiterating their points and checking for correctness in their reasoning.
Participants are working within the context of a homework problem, which may impose certain constraints on the assumptions they can make regarding the relationships between the variables involved.
whynot314
A=[itex]\pi[/itex][itex]r^{2}[/itex]
therfore,
[itex]\frac{dA}{dt}[/itex]=2[itex]\pi[/itex][itex]\frac{dr}{dt}[/itex]
The question is if [itex]\frac{dr}{dt}[/itex] is constant is [itex]\frac{dA}{dt}[/itex] constant?
To me, I know that if the change in radius with respect to time is constant, The rate of change of the are with respect to time still depends on the radius of the circle at some time. Therefore dA/dt is not constant.
Is this right?
Also am I wording this correctly?
therfore,
No.
$$ \frac{dA}{dt} =2\pi r \frac{dr}{dt}$$
Does what I wrote answer your question?
Is this right?
whoops yea forgot the r there, That was the r I was talking about in my answer. so what I said still applies right?
Right, dA/dt is not constant. Even if r increases at a constant rate (i.e., dr/dt is constant), dA/dt does not change at a constant rate.
Thanks
