Inductance of Solenoid on Coaxial Cable
The discussion revolves around the inductance of a solenoid and its interaction with a coaxial coil. The problem involves calculating the magnetic field produced by the solenoid, the induced emf and current in the coil, and the mutual inductance of the system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the nature of the magnetic field inside and outside the solenoid, questioning whether it is constant or zero in certain areas. There are attempts to relate the magnetic flux to the magnetic field and the area of the solenoid, with some participants clarifying definitions and equations related to mutual inductance and induced emf.
Participants are actively engaging with the problem, exploring different interpretations of the magnetic field and flux. Some have provided calculations for the induced emf, while others are clarifying the relationships between the variables involved. There is a mix of agreement and questioning regarding the definitions and equations used.
Participants note that the solenoid can be approximated as infinite, which influences their understanding of the magnetic field distribution. There is also mention of specific values and constraints provided in the problem statement, such as the number of turns and the dimensions of the coils.
ArtVandelay
The figure below shows a short coil which is coaxial with a very long solenoid (you may approximate it as infinite.)
Coil: Has 120 turns of radius 1.8 cm and resistance 5.8 . It is not attached to anything.
Solenoid: Has 22700 turns/m and a radius of 1.6 cm. It receives an external current (source not shown).
a.) The magnetic field across the coil's entire cross-sectional area (as caused by the solenoid) at any given time: ?
b.)
If the current supplied to the solenoid drops at a constant rate from 1.5 A to zero in in a time interval Δt = 25 ms, What are the magnitudes of the emf and current induced in the coil during this time interval?
c.) What is the mutual inductance of this solenoid/coil system?
Mutual inductance of coil 2 with respect to coil 1 = M12 = ( N2 * flux12 ) / I1
Mutual-induced emf by 1 on 2 = ε2 = - M * d/(dt) * I1
Bsolenoid = μoNI/l
flux = integral of B dot dA
For part (a):
Is a non-zero constant inside the solenoid and zero everywhere else?
For part (c):
I get the mutual inductance, M, is equal to ( μo * N1 * N2 * Area ) / length, however I'm not given a length.
ArtVandelay said:
Let"1" refer to the solenoid and "2" refer to the coil.
You have B1 = μ0n1i1 (well-known solenoid formula, n1 = no. of turns per meter)
You also have Farady's law: emf2 = -N2*d(flux2)/dt
so what is flux2 in terms of B1?
Then substitute B1 in the eq. for emf2.
You further have, by definition,
emf2 = M di1/dt, M = mutual inductance.
So now solve for M.
For part (a):
Constant?
flux2 = n2 * B1 * A1, where A1 is cross-sectional area of the solenoid.
Thanks! Got that part right, now working on the rest.
Thanks! Got that part right, .
No, I don't think you did.
Isn't flux always some B times some A? What does N or n have to do with it?
Oops, you're right. flux2 should just be B1 * A1. Though this is where I'm getting confused right now. On my equation sheet, provided by the instructor, our equation for magnetic flux looks like the following: flux = N * Integral ( B dot dA ) :/
In the end [of that part of the problem] I got emf2 = ( μo * N2 * N1 * Ii * A1 ) / Δt, where Ii is the initial current (1.5A), A1 is the cross-sectional area of the solenoid, and Δt is 0.025s. It came out to 165.18mV, which was marked correct.
rude man said:
Constant?
Recall from the problem, it states: "very long solenoid (you may approximate it as infinite.)"
So I have four choices for part a, which asks, The magnetic field across the coil's entire cross-sectional area (as caused by the solenoid) at any given time ...
1) is zero across the entire area
2) is a constant non-zero value across the entire area
3) is a zero value in some locatoins an a constant non-zero value in others
4) varies continuously across the entire area.
From what I've read, I'm thinking the magnetic field outside the solenoid is zero, and that inside the solenoid it is pretty much constant.
You have to look at the context. Maybe he/she meant that the flux due to N windings in a solenoid is N times the flux due to 1 winding, etc. But flux = ∫B*dA always.
Your N1 should be n1, no. of turns per meter. But that's what you obviously used to get the right answer. Just remember the distinction ... :smile:
That's what I'm thinking! :smile:
Thank you for your help.
You're most welcome.
  • · Replies 17 ·
