Barometric pressure and the math behind it. Very interesting, I think.
  • Context: High School
  • Thread starter Thread starter jasonlr82794
    Interesting Pressure
The discussion centers on the relationship between barometric pressure and sea level, highlighting Edmond Halley's contributions to this field. Barometric pressure is defined as the atmospheric pressure exerted by the air, and it serves as a reference point for measuring altitude. The conversation also touches on the implications of barometric pressure for fishing, suggesting that fish behavior may be influenced by pressure changes. Additionally, a dropping barometric reading is noted as an indicator of approaching storms, advising caution for those on large bodies of water.
  • Understanding of barometric pressure and its measurement
  • Familiarity with atmospheric pressure concepts
  • Basic knowledge of altitude measurement using barometers
  • Awareness of weather patterns and their impact on fishing
  • Research the mathematical relationship between barometric pressure and altitude using the barometric formula
  • Explore the physics of atmospheric pressure and its effects on weather systems
  • Learn about the use of barometers in meteorology and their calibration methods
  • Investigate how barometric pressure influences aquatic life behavior, particularly in fishing
This discussion is beneficial for meteorologists, fishermen, environmental scientists, and anyone interested in the effects of atmospheric pressure on weather and aquatic ecosystems.
jasonlr82794
Hey guys, I was actually researching the life of Edmond Halley and discovered that he discovered the relationship between barometric pressure and the height of the sea level. I'm not quite sure what barometric pressure is( I know it has a lot to do with whether fishermen fish or not) and would like to know. Can you also show me some mathematical examples on how to find this and the mathematical relationship between these two things. Also, what is the physics behind this interesting phenomenom. Thank you.
I'll do my best to help, but I think you may be confused about something because what you are saying doesn't make a lot of sense.
-Barometric pressure is just the pressure exerted by the atmosphere (and FYI, you should always start by googling simple terms): https://en.wikipedia.org/wiki/Atmospheric_pressure
-Barometric pressure doesn't have much to do with sea level except insofar as sea level is used as the zero point for measuring altitude. You can use a barometer to measure altitude since pressure varies with altitude (if you calibrate it to the day's sea level pressure: http://en.wikipedia.org/wiki/Altimeter#Pressure_altimeter
-As for fish; someone else will have to weigh-in, but I suspect it has something to do with their ability to sense and control depth. Perhaps when atmospheric pressure is higher they swim closer to the surface (because they think they are deeper than they are).
The best fishing I ever did was on lake in a small aluminium boat right before a storm hit. You cast out and pulled a pickeral in 5 minutes.
Also, a dropping barometric reading most times indicates that a storm or foul weather is approaching so if you are out on a large lake or out at sea, it might be best to head to port if your ship is not one that can withstand large waves.
I will add a link with some interesting weather/ barometric pressure relationships.
http://weather.about.com/od/weatherinstruments/a/barometers.htm
  • · Replies 20 ·
24K
  • · Replies 20 ·
  • · Replies 102 ·
11K
