Current in inductor used to measure EMF.
The discussion revolves around the implications of reversing the current direction in an inductor used to measure electromotive force (EMF), referencing Faraday's law of electromagnetic induction. Participants are exploring the relationship between current, magnetic flux, and induced EMF.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning whether reversing the current affects the induced EMF and discussing the nature of magnetic flux as a scalar with associated direction. There are considerations about the relationship between flux and current, particularly how the rate of change of flux might be influenced by the direction of current.
The discussion is active, with participants offering insights into the relationship between current and flux. Some have provided mathematical expressions relating current and EMF, while others are probing the implications of changing current direction on these quantities. Multiple interpretations of the problem are being explored without a clear consensus.
Participants note that this inquiry is not a formal homework question, which may influence the depth of analysis and the rigor of the responses. There is an ongoing examination of assumptions related to the behavior of flux and its dependence on current direction.
peripatein
Hi,
This is not a formal HW question, yet I was wondering whether one of you might be willing to answer it nevertheless.
According to Fraday's law, ε = -∂[itex]\phi[/itex]/∂t. If I reversed the direction of the current in an inductor used to measure ε, would that have any effect on ε?
I would think it wouldn't, but am not certain. Wouldn't the flux remain the same once the current is reversed? Or, rather, the rate of change of flux?
Flux even it is a scalar, did some direction is associated with it (at a point)?
No, but could the rate of change of that scalar once the current is reversed change?
Relate the flux linking the turns of the inductor, ϕ, to the current through it, i, by:
ϕ = L*i
where L is the self-inductance of the inductor and is considered a constant.
You would have to calculate the surface integral that gives you ϕ such that it has the same sign as i for some choice of reference direction of i. You have then:
ε = -dϕ/dt = -L di/dt
As an example, if the current i was increasing with time, -i would be decreasing, e.g. the sign of di/dt and ε would flip.
peripatein said:
Hi,
emf = L di/dt. So if i is increasing and positive, emf is positive.
If i is negative and increasing (in magnitude), di/dt is negative and so is emf.
  • · Replies 27 ·
  • · Replies 55 ·
11K
