Can I determine pressure loss by only using cfm & psi at 2 locations?
The discussion revolves around the feasibility of determining pressure loss in a compressed air system using only measurements of cubic feet per minute (cfm) and pounds per square inch (psi) at two locations. Participants explore the implications of various factors affecting pressure loss, including piping layout, fittings, and flow dynamics.
  • One participant questions the consultant's claim that measuring cfm and psi at the header can determine pressure loss, suggesting that other variables like temperature, distance, and pipe characteristics must also be considered.
  • Another participant asserts that if pressure loss cannot be measured with two gauges, a reevaluation of the approach is necessary.
  • A participant proposes a method to calculate pressure loss by subtracting the pressure at the point of usage from the pressure at the compressor header, while also inquiring about the availability of gauges that measure total pressure.
  • It is noted that friction from airflow through fittings and pipes contributes to pressure drops, and that transient effects may occur when the sandblaster is activated, but these effects are expected to stabilize after a brief period.
  • One participant references external resources for pre-analyzing the system, mentioning charts related to horsepower and pressure loss in pipes, while also expressing uncertainty about specific figures related to fittings and elbows.
Participants express differing views on the adequacy of using only cfm and psi measurements to determine pressure loss, with some supporting the idea while others highlight the need for a more comprehensive analysis involving additional factors. The discussion remains unresolved regarding the effectiveness of the proposed measurement approach.
Participants acknowledge the complexity of the system and the potential need for a qualified engineer to analyze the current piping layout and provide necessary tools and information for accurate assessment.
reedcj1
I work for a manufacturing company. We want to make some improvements to our compressed air system, but we want to establish a baseline of our current efficiency for cost justifications, etc. One planned improvement, is redesigning our current piping layout. We spoke with a consultant who wants to sell us several gauges to measure cfm and psi at various locations in the facility. He claims by measuring cfm and psi at the header nearest compressor, we will be able to determine pressure loss from header to point of usage. Is this possible or is he just trying to sell product? Are there not other variables that need to be considered (ie: temperature, distance in pipe, number of fittings, types of fittings, pipe diameters, etc.) ? I realize we only need ballpark figures for justification, but can we measure pressure loss by only knowing cfm and psi at two given locations?
If you can't measure pressure loss with two pressure gauges, it's time to start over.
I’m sorry, I am not an engineer and know little about fluid dynamics, so I am having trouble with this. We are trying to determine pressure loss due to the facilities current piping layout (ie: undersized pipe diameter, multiple fittings, switchbacks, etc.) Let’s say I place gauge at a 4” compressor header (Gauge 1), and a gauge on a 1” line 300ft downstream (Gauge 2) at point of usage (sandblaster). Assuming we are at steady state, static pressure at Gauge 1 and Gauge 2 should be equal. Now if I start the sandblaster I will exhaust the compressed air through a 1” line at Gauge 2, and create a transient system. Is it as simple as taking pressure at Gauge 1 minus pressure at Gauge 2 to determine Pressure Loss? Pressure Loss = Total Pressure1 – Total Pressure2. Are there gauges that measure total pressure? Total Pressure = Dynamic Pressure + Static Pressure.
If you are using compressed air in your system, the friction produced by the flow of the air thru fittings, valves, lengths of pipe, etc., will produce pressure drops in the system. Allowing the pressure to exit thru a sand blaster will create a temporary transient for a brief period after opening the valve, but any transient effects should die out after a certain interval.
I don't know how complicated your system is, and I don't know the qualifications of your consultant. If you want to improve your current piping layout, then the current layout should be analyzed by a qualified engineer. IMO, the engineer will provide his own tools, gauges, whatever is necessary for him to do his job. I would recommend that your management and the engineer understand beforehand what the engineer will do, what results he is to furnish, and what additional equipment or information he requires before the project commences.
The dynamic pressure is related to the volumetic flow rate - ie cfm.
You can pre-analyze your system with some charts.
http://www.engineeringtoolbox.com/horsepower-compressed-air-d_1363.html
as it says add 10 to 15% fro friction of the air compressor
http://www.engineeringtoolbox.com/compressed-air-pressure-loss-d_1014.html
for a pressure loss in pipe. For each reduction or elbow, I think you add about 10 feet of straight pipe but I am not sure of that figure.
http://www.engineeringtoolbox.com/air-line-length-recommended-sizes-d_1537.html
for recommended sizes of pipe.
( right now the site is slow for some reason - just wait it out )
15K
  • · Replies 39 ·
18K
  • · Replies 24 ·
