Electric circuits problems, finding current.
The discussion revolves around a series circuit problem involving resistors and the effect of introducing a wrench with small resistance. Participants are exploring the implications of current measurements before and after the wrench is introduced, questioning the behavior of current in series versus parallel configurations.
  • Participants discuss the initial current measurements and the changes observed when the wrench is introduced. There is confusion regarding the current through the wrench and the assumption that current remains constant in a series circuit.
Some participants have provided insights into the nature of the circuit and the potential for the wrench to create a parallel path, which may clarify the situation. Others are still grappling with the calculations and the implications of the circuit setup.
There is uncertainty regarding the resistance of the wrench and how it affects the overall circuit dynamics. Participants are also considering the impact of the wrench's placement within the circuit.
physics604
1. A series circuit initially consists of a cell of unknown voltage, a resistor R2 of 4.0 Ω, and another resistor R2 of 6.0 Ω. A student measures the current through R2 to be 3.0 A. When a wrench that has a small resistance is dropped on the circuit, the current through R2 is reduced to 1.0 A. What is the current flowing through the wrench? (Assume the supply voltage remains constant.)
a) 1.0 A
b) 2.0 A
c) 5.0 A
d) 7.5 A
To summarize:
R1=4.0 Ω
R2= 6.0Ω
I2 initially= 3.0 A
I2 with wrench= 1.0 A
Find I (current) going through the wrench.
V=IR
My answer is a) 1.0 A, but it is wrong. The correct answer is c) 5.0 A but I don't understand why.
I was told that in a series circuit, the current should be the same throughout. So in the circuit (with wrench), if the current is measured after a resistor to have a current of 1.0 A, shouldn't the current through the wrench be the same?
a) 1.0 A
b) 2.0 A
c) 5.0 A
d) 7.5 A
To summarize:
R1=4.0 Ω
R2= 6.0Ω
I2 initially= 3.0 A
V=IR
Dropping the wrench onto the circuit is unlikely to insert the wrench into the series scenario. Instead, it will likely lie across some component, providing a parallel path...
Initially:
R1 = 4.0 Ω
I1 = 3.0 A
V1 = 12.0 V
R2 = 6.0 Ω
I2 = 3.0 A
V2 = 18.0 V
So VT = 30.0 V
With wrench:
VT = 30.0 V
R1 = 4.0 Ω
I1 = 1.0 A
V1 = 4.0 V
R2 = 6.0 Ω
I2 = 1.0 A
V2 = 6.0 V
Vwrench = 20 V
But I still don't know R of the wrench so I can't figure out I.
Gneill correctly states, Dropping the wrench onto the circuit is unlikely to insert the wrench into the series scenario. Instead, it will likely lie across some component, providing a parallel path...
Draw a diagram of the initial circuit. Then figure out where you could drop a wrench that would reduce the current through R2. Then work the circuit.
Okay, I got it! (plus the three other questions I posted as well).
Thanks!
  • · Replies 20 ·
