Solving Circuits with Kirchhoff's Laws: A Rigorous Mathematical Approach
  • Context: Graduate
  • Thread starter Thread starter Bipolarity
    Circuit
The discussion revolves around the solvability of electrical circuits using Kirchhoff's laws and Ohm's laws, particularly focusing on the mathematical foundations and potential limitations of these methods. Participants explore whether all circuits can be solved under various conditions, including the introduction of dependent components and pathological cases.
  • Some participants propose that circuits consisting of ideal batteries and resistors can generally be solved using Kirchhoff's laws and Ohm's laws, but question the existence of a rigorous mathematical proof for this assertion.
  • Others mention that in circuits with N nodes, there are N unknown voltages leading to N-1 independent linear equations, suggesting a potential for solvability.
  • Pathological cases, such as connecting batteries with unequal voltages in parallel, are highlighted as scenarios where the circuit cannot be solved, raising questions about the conditions under which circuits can be solved.
  • Participants discuss the implications of ideal components and the necessity of including non-ideal elements, such as small resistances, to ensure solvability in practical scenarios.
  • Some suggest that a rigorous proof would need to identify and exclude unrealizable cases while demonstrating that most practical circuits are solvable.
  • There is mention of using linear algebra techniques to analyze circuit equations, including checking for the invertibility of coefficient matrices.
Participants do not reach a consensus on whether a general proof exists for the solvability of all circuits. Multiple competing views are presented regarding the conditions necessary for solvability, the role of ideal versus non-ideal components, and the existence of pathological cases that complicate the discussion.
Limitations include the dependence on definitions of ideal components, the potential for linear dependence among equations, and the unresolved nature of certain mathematical steps in proving general solvability.
Bipolarity
Let's say I have a circuit consisting only of a finite number of batteries and resistors, all ideal. Given an arbitrary shape of this circuit, will I always be able to "solve" this circuit, i.e. find the missing variables (current through any wire, voltage across any two points) by using the Kirchhoff's laws in conjunction with Ohm's laws?
If yes, can this be proven mathematically? Where would I find a proof? Surely it involves proving that a certain coefficient matrix of some linear system is invertible? Perhaps it will require some graph theory?
If not, under what conditions can the circuit be solved for?
What about when we add dependent components to the circuit?
One thing I noticed is that if you have a circuit with N nodes and write out equations for all nodes, 1 of the equations will be linearly dependent on the other (n-1) equations.
I am reading my introductory circuits text, but have a good linear algebra background, so I like to see a very rigorous justification of the methods employed by my text.
Thanks!
BiP
Yes. In a problem with N nodes there are N unknown voltages. As you noticed, this always results in a system of N-1 independent linear equations. Since you can arbitrarily set anyone node as ground that gives you N equations in N unknowns.
I don't know about a rigorous proof.
I don't know about a rigorous proof either.
However, there will be pathological cases. For example, putting two batteries with unequal voltages in parallel is a no-no.
What happens if you did do that?
BiP
Booooommmmm
Calculate the current flow. Ohms law says..
V=IR
so
I = V/R
but
R=0
so
I=∞
Then
Power = Voltage * Current
so
Boooommmm
Some batteries really do go bang. Depends how well they approximate an ideal voltage source. Some relatively ordinary rechargable batteries can manage several hundred amps (but not for long).
Other things to avoid include disconnecting (open circuiting) an ideal current source.
Lithium battery short circuited...
BiP
Well, above you see the practical concerns, but I was thinking more about the mathematics. Just write out the equations to see it.
V1=V2 Kirchhoff's Voltage Law
V1=10V Ideal voltage law for battery # 1
V2=20V Ideal voltage law for battery # 2
So, two batteries in parallel can't obey Kirchhoff's Voltage Law, or if they do, then at least one of them can't obey it's own ideal voltage law.
It's like an irresistible force pushing an unmovable object. It just can't be resolved logically.
Hence, any rigorous proof would isolate these types of pathological cases first, and then proceed to prove that the other cases are all solvable. Or, perhaps you already have your answer now because you set out to prove if all cases are solvable, but by showing even one case that is not solvable, it's clear that it can't be done.
As a practical matter, when solving real problems, these issues tend not to come up unless you make a mistake, and then the mistake (or poor assumption) becomes obvious when you can't get a solution.
Real circuits haven't read your textbook, and they don't care if your over-simplified models of idealised components don't have solutions. As I said in another thread recently, physics is not a sub-branch of mathematics!
To answer the OP's question - try working backwards. Write down a matrix equation that has no solutions, or multiple solutions (obviously the matrix must be singular). Then invent a circuit diagram that corresponds to the matrix equations.
You can add a tiny resistance in parallel to every voltage source to get a physical solution for all scenarios.
With batteries and resistors only, every connection between two vertices can be expressed as series connection of a voltage source (can be 0V) and a single resistor with a positive resistance.
I do not know if the star-mesh transform is possible with voltage sources inside. If it is, every circuit can be reduced to trivial circuits.
There are iterative ways to solve the equation system - it would be sufficient to show their convergence.
Well, mathematically you can always take a basic circuit like this and put it into a system of linear equations. Then you can use standard linear algebra techniques to solve it or to determine that it doesn't have a solution (i.e. determinant not equal to 0).
Well, yes, of course. The OP mentioned "invertibility" of the linear system, which I think amounts to the same thing. And, there are other ways to check it too. This is one point I was trying to make; that, as a practical matter, we can check it on a case by case basis as needed. However, if the OP truly wants a rigorous (and I assume that implies "general" too) proof, a case by case checking doesn't satisfy that. Another point I am making is that there are clearly some cases that are not solvable "given an arbitrary shape of this circuit". So, a general/rigorous proof would identify the unrealizable/pathological cases and (presumably) would show that the interesting real-world practical cases are all solvable.
This is just a guess on my part, but I think that requiring all ideal voltage sources to have a nonzero series resistor with it will give circuits that are practical and always have a solution. If this is correct, then this might be the starting point for the rigorous proof he wants. Using either graph theory or matrix formulations could allow him to show that a general system always has a nonzero determinant. But this does leave out some solvable cases that are not physical (let's ignore superconductivity for this discussion).
