Is this a linear system of equations?
The discussion revolves around the classification of a system of equations as linear, specifically focusing on a matrix representation involving a non-linear function. Participants explore the implications of the function's characteristics on the linearity of the system.
  • The original poster questions whether a system of equations represented by a matrix involving a non-linear function qualifies as linear if certain variables are known and yield numerical values.
  • One participant suggests that if the function values are treated as constant coefficients, matrix inversion could be performed, implying linearity.
  • Another participant raises a concern that if the unknowns \( S_i \) are dependent on the function \( f \), the system would not be linear.
  • A further clarification is requested regarding the dependency of \( S_i \) on \( f \), with a call for an illustrative example.
  • Another participant asserts that if \( S_i \) is a function of \( x_i \) and \( f \) is also a function of \( S_i \), then the system cannot be classified as linear.
Participants express differing views on the conditions under which the system can be classified as linear, indicating that the discussion remains unresolved with multiple competing perspectives.
Participants reference definitions and examples from external sources, such as Wikipedia, to support their claims, but the applicability of these definitions to the specific system discussed remains uncertain.
nde
Hello everyone!
I have a question on whether a system of equations can be classified as linear. I have the following matrix:[itex] \begin{equation}<br /> \left[ \begin{array}{c} S_t(1) \\ S_t(2) \\ \vdots \\ S_t(\omega_N) \end{array} \right] = <br /> \begin{bmatrix} f(x_1, x_2, 1) & f(x_2, x_3, 1) & \cdots & f(x_i, x_{i+1}, 1) \\ <br /> f(x_1, x_2, 2) & f(x_2, x_3, 2) & \cdots & f(x_i, x_{i+1}, 2) \\<br /> \vdots & \vdots & \ddots & \vdots \\ <br /> f(x_1, x_2, \omega_N) & f(x_2, x_3, \omega_N) & \cdots & f(x_i, x_{i+1}, \omega_N) \\<br /> \end{bmatrix} <br /> \times <br /> \left[ \begin{array}{c} S_1 \\ S_2 \\ \vdots \\ S_i \end{array} \right]<br /> \label{equationsystem}<br /> \end{equation}[/itex]where [itex]f(x_i, x_{i+1}, \omega_N)[/itex] is a non-linear function containing two exponential terms and [itex]S_i[/itex] is unknown. Does this system of equations qualify as linear if I know [itex]x_i, x_{i+1}[/itex] and [itex]\omega_N[/itex] and plug it into [itex]f(x_i, x_{i+1}, \omega_N)[/itex] to yield a numerical value (real number)?
If this is true, I should be able to figure out [itex]S_i[/itex] by taking the inverse of the function marix and multiplying both sides with it.
I greatly appreciate your input. Thank you in advance for taking the time to answer this.
Kind regards.
Yes if the f(...) are considered constant coefficients then you can do the matrix inversion but if they are somehow dependent on the S unknowns then all bets are off.
Thanks for your reply. What do you mean when you say that the [itex]S_i[/itex] are somehow dependent on the [itex]f[/itex]? Could you please illustrate it with a simple example?
  • · Replies 25 ·
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 27 ·
