Potential Energy and Work done to lift object distance h
The discussion focuses on calculating the height to which a 1 kg object can be lifted using the energy generated by a 0.10 kW light bulb over 12 minutes. The calculation involves converting power from kilowatts to watts and time from minutes to seconds, resulting in a total work output of 72,000 joules. Using the formula for potential energy (PE = mgh), the height (h) is determined to be 7347 meters, based on a gravitational constant of 9.8 m/s². This result, while mathematically correct, raises questions about its practical feasibility.
  • Understanding of basic physics concepts such as potential energy and work
  • Familiarity with the formulas for power, work, and gravitational potential energy
  • Ability to perform unit conversions (e.g., kW to watts, minutes to seconds)
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Explore the implications of energy conservation in mechanical systems
  • Learn about the limitations of potential energy calculations in real-world scenarios
  • Investigate the relationship between power output and energy consumption in electrical devices
  • Study the effects of varying mass and gravitational acceleration on potential energy
Students and educators in physics, engineers working with energy systems, and anyone interested in the practical applications of potential energy calculations.
physicsballer2
Potential Energy and Work done to lift object distance "h"
The amount of energy needed to power a 0.10 kW bulb for 12 minutes would be sufficient to lift a 1 kg object how high?
Power = work/time
PE = mgh
First I converted kw to watts which is 100 watts. Then converted minutes to seconds = 720 seconds.
I found the work done by the lightbulb:
power = work/time
100 = w/720
w = 72,000 joules
Then I plugged that into potential energy(not sure if you can do that), I solved for h using 9.8 for gravity and 1 kg for mass
PE = mgh
72,000 = (1)(9.8)h
h = 7347 meters
That number seems a bit high
That looks good to me.
  • · Replies 22 ·
