Why angle of projectile has 2 solutions?
  • Context: Undergrad
  • Thread starter Thread starter e-zero
    Angle Projectile
The discussion revolves around the mathematical reasoning behind the existence of two solutions for the angle of a projectile when solving the equation sin(2θ) = 0.871. Participants explore the implications of this equation in the context of projectile motion, addressing both the mathematical and physical interpretations.
  • Some participants note that sin(2θ) = 0.871 leads to two possible angles for θ, specifically 30.3 degrees and 59.7 degrees, due to the properties of the sine function.
  • Others explain that the square root of sin²(θ) can yield both positive and negative values, which may contribute to multiple solutions.
  • A participant emphasizes the importance of understanding which equation is being solved, questioning whether it is sin(2θ) or sin²(θ), as this affects the interpretation of the solutions.
  • Some participants discuss the implications of the tangent function and how it may yield different solutions, noting that tangent does not repeat values in the same way as sine and cosine.
  • There is mention of the physical context of projectile motion, suggesting that the angle should be constrained to a range of 0 to 90 degrees for practical applications.
  • Several participants express uncertainty about the original poster's calculations and the clarity of the problem being addressed.
Participants generally agree that there are two angles corresponding to the equation sin(2θ) = 0.871, but there is disagreement regarding the interpretation of the solutions and the correctness of the original calculations. The discussion remains unresolved regarding the clarity of the problem and the mathematical steps involved.
There is uncertainty regarding the assumptions made in the original problem, particularly the equation being solved and the physical constraints on the angle θ. Participants also highlight the need for clarity in the mathematical steps taken to arrive at the solutions.
This discussion may be useful for students and enthusiasts of physics and mathematics who are exploring the relationships between trigonometric functions and projectile motion, as well as those interested in the nuances of solving trigonometric equations.
e-zero
I have the final answer of:
sin2(theta) = 0.871
why does (theta) = 30.3 deg OR (theta) = 59.7 deg
I get why this could be physically, but I'm not sure why mathematically?
Mathematically the sqrt of sin^2(theta) would be sin(theta) or -sin(theta) giving two possible thetas as a solution in the domain of thetas from 0 to 90 degrees.
I believe that you are trying to solve "sin ( 2 theta ) = 0.871" for theta.
This yields two solutions because theta can be about 30 degrees and then 2 theta is about 60 degrees (high in the first quadrant) or theta can be about 60 degrees and then 2 theta is about 120 degrees (high in the second quadrant).
The arc-sine function on your calculator would, of course, return only the first of these two possibilities, ignoring the second quadrant solution.
If you are solving the equation sin2θ=0.871 then, as jedishrfu said, sinθ = ± 0.933 which gives you a positive value for θ if the projectile is launched to go up from the axis of reference or a negative value of θ if the projectile is launched to go down.
One reason for discarding that interpretation is that the two solutions given in the original post were 30.3 and 59.7 degrees.
sin(2*30.3) = 0.871
sin(2*59.7) = 0.871
By contrast, if sin theta = ±0.933 then theta would be ±68.9 degrees. Those aren't even close to the solutions we're being asked to explain.
sin(2*30.3) = 0.871
sin(2*59.7) = 0.871
First of all he hasn't made clear which equation he is solving. Is he solving the sin2θ=0.871 or the sin(2θ)=0.871? I covered just one of the 2 occasions.
Secondly, we cannot be sure that he has done the math correctly.
Moreover, we don't even know what problem he is trying to solve. He just gave what he claims to be his final answer. We don't know anything about the rest of the solution.
Well, the given solutions of 30.3 and 59.7 degrees are consistent with [itex]\sin(2 \theta)[/itex], so I think it is pretty clear which equation it is.
The final answer was derived from the formula:
R = (v0^2 * sin2θ) / g
where θ is the angle I am trying to solve for (in my case it is a football being kicked), R is the horizontal range, v0 is the initial velocity, and g is gravity.
I guess a another way to put the question is:
If I see sin2θ in a formula, does that mean that there is potentially two angles for the answer??
Depends on the constraints of theta for the problem at hand. In the current problem theta could range from 0 to 90 degrees. In the domain of sin (theta) from 0 to 180 degrees (ie positive sin value) there are two angles that have the same sin.
When you consider 2*theta and with a positive sin constraint you still have two angles within the range of 0 to 90 degrees.
So let's say for arguments sake that I had:
tan2(theta) = 0.871
What could be the solutions for theta?
So mathematically speaking, what two angles are solutions for tan2(theta) = 0.871 ?
You know one solution is
2θ=arctan(0.871)​
Then you have to think about whether the tangent function repeats any values during a period, the way sine and cosine do, which would generate additional solutions. Tangent does not do this, so we're good there.
Finally, we can add or subtract integer multiples of the tangent function's period, namely π, to the above equation,
2θ=arctan(0.871) ± nπ,
and you check whether that generates additional solutions.
Discard solutions that differ by 2π from another solution, since they are really the same angle. Also discard any solution that is unphysical or for any reason meaningless. For example, a projectile launch angle should not be greater than 90°, unless you want to consider the projectile being fired backward for some reason, then it should be under 180°. On the other hand a compass heading could be anywhere from 0 to 360°.
For this last part, you are not relying on memorizing any rule. You have to think about the physical meaning behind the answers that the math spits out.
I kinda a get what your saying...
When I go back to sin2(theta) = 0.871 I get the following:
http://www.wolframalpha.com/input/?i=sin(2*+x)=0.871
My question now is how do I know that the two angles are approximately 30.3 deg or 59.7 deg by looking at the graph in the above link?
The x-axis is in radians so convert the 30.3 degrees radians and check again.
Remember 90 degrees is PI/2
Ok, can you explain how to appropriately calculate the solutions just using a calculator for the following?
sin2θ = 0.871
cos2θ = 0.871
tan2θ = 0.871
If sin 2θ = 0.871 then...
2θ = arcsin ( 0.871 ) or, since the sin function is symmetric about 90 degrees...
2θ = 180 - arcsin ( 0.871 )
So
θ = arcsin ( 0.871 ) / 2 or
θ = ( 180 - arcsin ( 0.871 ) ) / 2
So put your calculator into Degrees mode (often the default).
Key in 0.871
Click on inverse sin -- giving a figure of 60.575
Click on the divide by sign and key in 2.
Click on the equal sign -- giving a figure of 30.3
Key in 180 and press the minus sign
Key in 0.871 and click on inverse sin -- giving a figure of 60.575
Click on the equal sign -- giving a figure of 119.425 [this is 180 - arcsin(0.871)]
Click on the equal sign -- giving a figure of 59.7
So you do the same for cos and tan?
How about you do the same instead?
That gets us 2 of the 4 solutions, if we are solving this as a math problem. We need to add integer multiples of the period 2π to those equations to find the other solutions.
2θ = arcsin ( 0.871 )+2π
gives another solution. Do the same for the "180-arcsin(0.871)" equation, and you get yet another solution.
Adding twice the period, 2*2π, gets us 390.3°, which is equivalent to 30.3° and thus not a distinct solution, so we can stop there.
Ok, at this point I'm just trying to understand the trigonometry here (just the math).
So your saying that sin2 ø=0.871 has 4 solutions?
Do you have a link that can explain this further? Or can you explain how to find all solutions for a given trig function? (currently searching google...:))
I tried to explain it in Post #21.
Alternatively you can take the graph you got at wolfram, then extend the sine graph for a full 2*pi, and see that it intersects the y=0.871 line in two more places.
EDIT:
If you can get a pre-calc textbook, you can look at the section on solving trig equations. Or try googling "solving trig equations". Here's is one of the links I found from a google search:
http://academics.utep.edu/Portals/1788/CALCULUS MATERIAL/5_3 SOLVING TRIG EQNS.pdf
Pages 15-17 have an example that is similar to what we have been discussing.
sin2(theta) = 0.871
I'm guessing, since you give very little context.
The short answer is, because this function is periodic. There are two places where a sine wave has value 0.871 in each period.
In context: It seems (from the subject) like you are solving some kid of projectile problem. When you are firing a projectile at a target closer than the maximum distance, then there usually are two solutions. Neglecting air resistance and for the simplest projectile problem of same-level to same-level, the maximum distance applies at 45 degrees elevation. To shorten the distance you can either raise or lower the angle. Raising it means the projectile flies higher, with a slower forward speed. Lowering it means the projectile flies less high, with a faster forward speed.
Two obvious physical solutions correspond to shooting the projectile from the launch point toward the target.
The two additional solutions correspond to having the projectile come back from the target to align with the butt of a down-and-left-pointing cannon. The time of flight (measured from cannon to target) is negative for these additional two cases.
Mathematically, as RedBelly98 has politely pointed out, the additional solutions are at +180 degrees (or +pi radians) from the obvious solutions. [Roughly 210 degrees and 240 degrees].
Thanks for all the help. I realize that their are physical constraints depending on the problem at hand. I was getting confused with the math itself, and I realized that I need to go over basic trigonometry which I have done and which you have all helped me with.
Thanks for all the replies!
  • · Replies 60 ·
