Metric on torus induced by identification of points on plane
The discussion revolves around the relationship between different definitions of the torus, specifically focusing on how to derive the induced metric from various representations, including parametric definitions and identification of points on a plane. The scope includes theoretical aspects of geometry and topology, particularly concerning metrics on surfaces.
  • Some participants propose defining the torus parametrically or through identification of opposite sides of a plane, questioning the relationship between these definitions and the resulting metrics.
  • One participant suggests that if a Riemannian manifold has a group acting by isometries, the metric on the manifold can descend to the quotient space, using the example of the plane and the group Z².
  • Another participant describes a method to realize the metric on the torus by mapping the plane into R^4, indicating that this results in a flat torus.
  • There is a discussion about whether the two methods of defining the torus lead to different induced metrics, with one participant referencing a specific metric derived from a pullback onto a surface.
  • Some participants clarify that identifying the edges of a square in the plane to create a torus results in inheriting a flat metric from the plane, while noting that different metrics can be applied based on how the square is parameterized.
  • Questions arise regarding the complexity of finding geodesics on the torus derived from the plane with identifications, with suggestions on extending the fundamental domain to facilitate this process.
  • One participant reflects on using angles to describe the torus, connecting this to the previously mentioned metrics and their implications for understanding the geometry of the torus.
Participants express differing views on whether the two methods of defining the torus yield the same or different induced metrics. The discussion remains unresolved regarding the specifics of the induced metrics and the implications for geodesics.
There are limitations in the discussion regarding the assumptions made about the metrics and their derivations, as well as the dependence on the definitions used for the torus. The complexity of finding geodesics is also noted but remains an open question.
Illuminatum
Hi all,
Perhaps I'm asking the wrong question but I am wondering about the relationship between different definitions of, for the sake of argument, the torus.
We can define it parametrically (or as a single constraint) and from there work out the induced metric as with any surface.
But we can also define it by considering the plane and identifying opposite sides. Is it possible to use this definition, equip the plane with Cartesian coordinates and then deduce the metric on the torus caused by the identification?
I hope I've explained myself and apologise if it's an ill-thought-out question.
Thanks,
I
Illuminatum said:
Hi all,
I
Yes, this is one way to put a metric on the torus. More generally, if you have a riemannian manifold and a group G acting by isometries such that the orbit space M/G is a smooth manifold, then the metric on M descends naturally to a metric on M/G. Your construction is an example of this with M=R² and G=Z².
You can realize this metric by mapping the plane into R^4 by the equation
1/[itex]\sqrt{2}[/itex](cosx,sinx,cosy,siny)
The image is a flat torus.
To add to Quasar's comment, one can put a flat metric on the Klein bottle because it is the quotient of a group of isometries of the plane. Just add to the standard lattice, the isometry
(x,y) -> (x+1/2,-y)
Hi - thank you so much for the replies :-D
So in the two cases above (assuming that the plane was initially a piece of ℝ2) are you saying that the two methods lead to different induced metrics? In the case of the pullback onto a surface we end up with
ds2 = (1 + a.cos(v))2du2 + a2dv2
in terms of parameters u and v (from http://mathworld.wolfram.com/Torus.html :-s).
Do I understand that you mean that if we do things by identification we have the torus with a flat metric
ds2 = du2 + dv2?
Sorry if I've misunderstood - topology isn't my strong point! If I have could you explain what the induced metric would be in the latter case and how it is worked out?
Thanks again,
I
ds2 = du2 + dv2?
Thanks again,
I
Sorry. It is my fault for being vague. If one identifies the edges of a square in the plane to make a torus then this torus inherits the metric ds^2 = dx^2 + dy^2 from the plane.
The embedding of the torus in R^4 parametrizes the torus with this metric. One can not realize the torus with this metric in R^3 since in R^3 no closed surface without boundary can have a completely flat metric.
However a torus can have many metrics and each one comes from a different metric on the square. The only requirement is that the metric on the square lines up on its edges. This lining up is what Quasar was talking about.
Ok great, thank you very much :-)
Two minor questions...
Presumably finding geodesics is non trivial if you use the plane plus identifications...or do you extend the fundamental domain and place image points for your end point and find the geodesics for those, then wrapping them back to the fundamental domain?
And so if I wanted the metric I wrote above (u and v) I guess I must first parameterise the plane with u and v satisfying the identification, place that metric on the plane and then make the torus by revolution?
Actually also I was thinking that since we often think of it also as S1xS1 I would have thought it natural to use two angles, say [itex]\theta, \phi[/itex] and use
[itex]ds^{2}= a^2d\theta^{2} + b(\theta)^{2}d\phi^{2}[/itex]
but I just realized whilst typing that of course b is precisely the factor 1 + a.cos(\theta) in my first post telling us how far away from the centre of the second circle we are given how far around the first one (I've fixed some radial parameter to 1 here, sorry)!
Ok, think I'm good - thanks very much indeed.
James
In general finding geodesics involves solving a differential equation. If the torus inherits its metric from the plane then its geodesics are the projections - "wrap arounds" - of geodesics in the plane. For the flat metric they are the projections of straight lines.A good parametized torus in 3 space is the sterographic projection of the flat torus in 4 space parameterized above. This torus looks like a curled up slinky. Since stereographic projection is conformal - it preserves infinitesimal angles - this torus is conformally flat. Try to figure out the geodesics on it.
  • · Replies 38 ·
9K
