What is the expected completion date for Olkiluoto-3 EPR in Finland?
  • Thread starter Thread starter Astronuc
    Epr
The discussion centers on the expected completion date for the Olkiluoto-3 EPR nuclear power plant in Finland, including its design, efficiency, and historical context. Participants explore technical aspects of reactor efficiency and advancements in turbine technology, as well as the timeline of the project's development.
  • Some participants note that the Olkiluoto-3 plant has a net electric output of approximately 1600 MW and a net efficiency of about 37%.
  • One participant questions whether 37% net efficiency is considered high for reactors, prompting a response that it is indeed good for a nuclear reactor.
  • Another participant explains that fossil fuel plants typically achieve around 40% efficiency, citing the limitations imposed by the Second Law of Thermodynamics on heat engine efficiency.
  • Discussion includes historical advancements in turbine design by Siemens in the early 1990s, which improved efficiency from about 33.5% to 37% through the introduction of advanced blade designs and computational fluid dynamics (CFD) simulations.
  • Participants discuss the impact of higher output temperatures in fossil fuel plants compared to nuclear reactors, which are limited to around 650°F.
  • There is mention of high temperature gas-cooled reactors (HTGRs) that can approach fossil plant efficiencies, with references to past HTGRs in the USA and German experiments.
Participants express differing views on the efficiency of nuclear reactors compared to fossil fuel plants, with some agreeing that 37% is a good efficiency for a reactor while others provide context that fossil plants typically perform slightly better. The discussion remains unresolved regarding the implications of these efficiency comparisons.
Participants reference various technical aspects and historical developments without reaching a consensus on the implications of efficiency ratings or the expected completion date of the Olkiluoto-3 project.
Astronuc
Staff Emeritus
2025 Award
http://www.tvo.fi/486.htm
Plant's net electric output approx. 1600 MW
Net efficiency approx. 37 %
In November 2000 Teollisuuden Voima Oy filed an application with the Finnish Government for a decision in principle on a new nuclear power plant unit. In January 2002 the Government made the decision in principle in favour of the new unit. This decision was ratified by the Parliament in May 2002. The project then proceeded to a bidding competition that took over a year. In October 2003 Olkiluoto was selected as the site for the new unit on technical and financial grounds. In December 2003, TVO selected the pressurised water reactor of the consortium formed by Framatome ANP and Siemens from the solutions offered in the bidding competition.
In January 2004 TVO filed an application with the Government for the construction license of Olkiluoto 3. According to the plans, the actual construction of the unit will start in the spring of 2005. Electricity generation at the new plant will start in 2009.
The new nuclear power plant unit is built at the west end of the island of Olkiluoto, next to plant units Olkiluoto 1 and 2. The total area required for the new unit is about four hectares.
The new power plant unit will utilise the existing infrastructure in Olkiluoto to a maximum extent. The infrastructure is also complemented in many respects.
The new power plant unit will provide permanent employment to 150 - 200 people. During the annual outages, some thousand people will be employed.
Nuclear News, March 2005
According to TVO, the consortium has assigned 700 designers to work on the project. Steam generator manufacturing is proceeding at Framatome ANP's factory in France, manufacturing of the pressure vessel has been started at Mitsubishi Heavy Industries, and the generator rotor has already been cast in Japan. The generator will be manufactured at Siemens' facilities in the US.
Is 37% net efficiency high for reactors?
theCandyman,
Yes - that's good for a reactor.
Fossil fueled plants will do about 40%
The 2nd Law of Thermodynamics puts limits on the efficiency of a
heat engine - which the Rankine steam cycle in any power plant is.
The hotter the source of heat - the more efficient the steam cycle can
be. Nuclear reactor output temperatures are limited to about 650 F
for a Pressurize Water Reactor [ PWR ].
The output temperature of a fossil fueled boiler is in the neighborhood
of 1000 F. So fossil plants have more efficient steam cycles.
The now shutdown Indian Point Unit 1, near Peekskill, NY; had an
oil-fired superheater to heat the steam out of the reactor, in order
to gain efficiency.
High temperature gas-cooled reactors can approach the efficiencies
of fossil plants. The only 2 HTGRs in the USA were Peach Bottom 1,
and Fort Saint Vrain, both shutdown. The Germans were experimenting
with high temperature gas cooled pebble bed reactors.
Dr. Gregory Greenman
Physicist
In the early 1990's Siemens introduced some advanced blade designs into their steam turbines. The blades were curve rather than straight, seals were improved to reduce by-pass, and stages were optimized. The net result is that a plant that was designed for 1450 MWe with the old turbine design (~33.5% efficient) can now produce 1600 MWe with the same thermal energy, thus realizing a 37% efficiency.
Siemens’ Muelheim an der Ruhr, Germany, engineering center is responsible for architecting design rules and tools used by the company’s worldwide engineering network to design turbines to customer specifications. In the early 1990s, the company moved from traditional 2D parallel-sided blades to 3D airfoil designs as part of a continuing effort to improve turbine efficiency. The change required major modifications to both design and manufacturing processes. The first generation of 3D blade designs were based on conventional quasi-3D blade design concepts addressing the issue that flow conditions vary along the height of the blade, along with the rotational speed. However, amid the development process, engineers recognized that fully optimizing the geometry of the blade would lever further efficiency improvements leading to a novel fully 3D blade design concept. "The use of a model turbine is only partially suitable of exploring these issues," Deckers explains. "One disadvantage is that it is very expensive to build and to instrument. Another issue is that the test results do not provide much information on the detailed flow fields inside the turbine, which are critical in understanding the underlying physics. We needed to get a better understanding of the flow and pressure fields inside the turbine, so we began looking at the various CFD tools in an effort to determine which one would give us the most help."
To achieve high efficiencies at Boxberg, Siemens engineers performed a comprehensive series of parametric simulations using CFX computational fluid dynamics (CFD) software from ANSYS Inc., Canonsburg, PA, in order to derive design rules that are used subsequently to generate optimized blade-path designs based on the pressure, temperature and mass flow rate defined by the customer. They varied the blade airfoils over the height of the blade to better suit local flow conditions, reducing losses associated with secondary flows. The company has also used CFD to reduce losses in the intake and exhaust flow channels. "CFX software played an important role in the development process by allowing us to predict flows and pressures inside the turbine with a minimum amount of model turbine tests", says Mathias Deckers, manager of Steam Turbine Blading Technology for Siemens, Muelheim an der Ruhr. "The CFD software also provides accurate trends in efficiency predictions, making it possible to try a large number of alternatives and pick the one that works best."
9K
