How to Calculate the forces when carrying a gurney
  • Thread starter Thread starter Science4ver
    Forces
The discussion revolves around calculating forces related to a soccer player lying on a gurney carried by two individuals. The problem involves determining the forces exerted by the gurney on the player at specific points and assessing the carrying capacity of one of the individuals involved.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants explore the use of gravitational force equations and center of mass calculations to determine the forces acting on the player. There are questions about the relevance of gravitational attraction between the gurney and the player versus the Earth. Some participants suggest using moments to analyze the forces based on the player's position on the gurney.
Participants are actively questioning the clarity of the problem statement and the assumptions made regarding the distribution of the player's weight. There is no explicit consensus on the method to use, but several lines of reasoning are being explored, including the calculation of forces and the application of moments.
There is uncertainty regarding the carrying capacity of the second individual, as it is not specified in the problem. Additionally, the lack of mention of friction between the player and the gurney is noted as a potential factor in the calculations.
Science4ver
A Soccerplayer is injured and placed flat on 2 meter long gurney carried by two men.
The soccerplayer has weight of 81 kg and the gurney has a weight of 10 kg.
1) Calculate the force from the gurney onto the player's hand which is at position 0.8 meters from the left end of gurney and Calcuate the force from the gurney on the plays hip which is at position 1 meters on the gurney.
2) One of guys who carry the gurney with the gurney with the player on it can only carry 450 N. How long does the player have to move on gurney to for this guy being able to do his job?
its not mentioned how much other guy is able to carry.
F = G * (m1 * m2)/r^2
1) Do I use the equation F = G * (m1*m2)/r^2 to calculate the two forces.
2) Do I calcuate the center of mass?
The problem statement is not clear, but I am pretty certain that the force of gravitational attraction between the gurney and the soccer player is negligible compared to the gravitation attraction between the Earth and the gurney and soccer player.
So, to answer your questions:
1. No.
2. Probably.
Thank you for your answer.
The only other way I can come up with would to first calculate the force enacted on gurney
F_Gurney = m_gurney * g
then the forces enacted on the person
F = m_person * g
and if the person is placed at position
delta x = 0.8 m the the amount of Force enacted on the person at that position
F_total = F_Gurney + F_person * delta x?
If not how would you surgest I calculate this? Because no friction between the man and gurney is mentioned in the problem.
Best Regards Alfred
Is the question quoted accurately? It would make more sense as:
1) Calculate the force from the gurney on the player in the vicinity of the player's hand ...
Then, assuming the player's mass is uniformly distributed along the gurney, you can use moments to get an answer.
Thanks for your answer, you version is what I meant. Its translated from a non english language :)
Which momentum formula do I use? Which takes position into account?
Cause I am only familar with
P=mv
Best regards
Alfred
The force the gurney applies to the player's hand and leg is exactly the force the hand and leg apply to the gurney- their weight. And that is not given in the problem.
Hello Hallsoftly and thank you for your answer. A previous poster mentioned this problem could solved by calculating the momentum at the hand and hip at their respective position? Because the acceleration look to me to be zero?
I wrote 'moment', not momentum. But it was nonsense anyway. If, as I suggested, you have to assume the player's weight is uniformly distributed then all you can calculate is the force per unit length - it doesn't make sense to ask what the 'force' is at a given point. And it will be the same at all points along the gurney.
Maybe the translation is still not quite right.
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 17 ·
