Q* (the set of rational cuts) has least upper bound property or not?
The discussion centers on the least upper bound (LUB) property of the set of rational cuts, denoted as Q*. The reasoning presented claims that if Q* is defined as the set of all rational cuts, then any subset A of Q* has a supremum Υ, which is also a cut in Q*. However, this conclusion contradicts established mathematical principles, as the union of certain rational cuts does not yield a rational cut, exemplified by the set of all rational cuts x such that x² < 2, which does not include √2. Therefore, Q* does not possess the LUB property.
  • Understanding of Dedekind cuts and their properties
  • Familiarity with the concept of least upper bounds in real analysis
  • Knowledge of rational numbers and their properties
  • Basic principles of set theory and unions of sets
  • Study the properties of Dedekind cuts in detail
  • Explore the implications of the least upper bound property in real analysis
  • Investigate the differences between rational and real numbers regarding completeness
  • Examine counterexamples in set theory related to unions of cuts
Mathematicians, students of real analysis, and anyone interested in the foundational properties of rational and real numbers.
saurabhjain
I am struggling to draw this point home:
To prove that R has LUB property, we used the following reasoning:
First we defined R to be set of cuts (having certain properties) where each cut corresponds to a real number and then we proved any subset A of R has LUB (least upper bound) property.
If I use similar approach to define Q* to be the set of all rational cuts.
Then let A be the subset of Q*. Let Υ be the union of all cuts in A. Then this Υ is a cut in Q* and is supremum of A.
(Note, to define Q* above, we didn't need to introduce R, as we are playing with only rational cuts so far.)
Is above reasoning false? and if false, how to prove it.
If the reasoning is true, then the coclusion that Q* has LUB leads contrary to what we have read in the books (i.e. Q does not have LUB). Or the conclusion with the help of cuts that R has LUB has problem?
Your reasoning is incorrect. In the set of all Dedekind cuts (defining the real numbers) we can show that the union of all cuts less a given cut is itself a Dedekind cut and so defines the least upper bound. If we take, for example, the set of all rational cuts x, such that [itex]x^2< 2[/itex], the union is not a rational cut.
Thanks a lot! The sqrt 2 example above, makes the picture clear.
