Potential electricity production from water passed through Magma.
The discussion revolves around the theoretical potential for electricity production from water heated by magma in a controlled setup. Participants explore the feasibility of using molten magma as a heat source to generate steam and subsequently electricity, drawing parallels to existing coal-powered plants.
  • One participant proposes a scenario involving 50 MT of magma at 700°C and seeks educated guesses on the electricity that could be produced from steam generated by water passing through a pipe wrapped around the magma.
  • Another participant questions the practicality of sourcing magma and addresses the need for specific parameters such as the amount of magma, water availability, and boiler specifications to estimate electricity production accurately.
  • A participant provides a theoretical formula for calculating the heat released by cooling magma, emphasizing that only a fraction of this heat would convert to electricity, factoring in the efficiency of the power plant.
  • One participant mentions that geothermal energy already utilizes similar principles, suggesting that the concept is not entirely novel.
  • Another participant notes the poor heat transfer characteristics of magma, especially when solidified, and highlights the need for extensive piping or slow water flow to optimize the system's efficiency.
Participants express differing views on the feasibility and efficiency of using magma for electricity generation. While some acknowledge the theoretical basis for the idea, others raise practical concerns about heat transfer and the specifics required for a successful implementation. No consensus is reached on the viability of the proposed system.
Limitations include the lack of specific data on magma sourcing, water availability, and the operational parameters of the proposed system. The discussion remains theoretical without resolved mathematical steps or definitive conclusions.
Iou
Dear Physicists
I am well aware that this question does not have all the necessary information on order to get an exact answer, but what I am hoping to find is some educated guesses backed by some math.
Lets imagine a 50 MT Pot filled with magma that is 700 C hot. Let’s imagine a thin pipe wrapped around this pot (Spiraling up to the very top). And let’s imagine a usual coal powered plant and how it works.
The question is how much electricity can be produced from the steam that occurs from the process of the water boiling whilst passing around the hot pot. (After the water boils, it creates steam which spins a tubing which is connected to a generator ect.)
Your help would be highly appreciated.
Thank you in advance and best regards
Where are you going to get the magma from? What are you going to do with it after it cools down and solidifies? How much electricity produced will depend on knowing how much 'magma' do you have available, How much of water is available to be heated, how much of steam pressure the boiler can withstand, size of boiler, etc.
Dear physwizard, thank you for your reply
This is a theoretical scenario. 50 MT of Magma in a pot. It will be disposed of after it solidifies; the amount of water available is unlimited. Not sure about the pressure.
Here is a link to a picture:
http://www.hk-phy.org/energy/power/elect_is/images/powerplant_still_eng.gif
This should help understand the scenario I am talking about.
In my case however, instead of the pipe passing thorough a room which has boiling coal in it, it will be wrapped around a huge metal pot filled up to the top and containing molten magma.
A coal powered plant produces about 1800 Kw/h from 1 MT of coal. How much Kw/h could be prodused from 50 MT of 700 C magma held in a pot, creating steam out of the water which passes through a pipe wrapped around it. Pipe can be any thickness.
Would like to get a rough idea
Thank you and best regards.
Hi, theoretically, the heat released by the magma during cooling will be given by: Heat released = mass * specific heat * (700 C - (Temperature to which the magma is cooled)). If you allow it to cool so much that it solidifies then you will have to add the latent heat to this, this would be = mass * Latent heat of fusion. This would only be the heat released during cooling. Only a fraction of this would be converted to electricity. So you would have to multiply this with the efficiency that you expect your power plant to have to get the amount of energy converted to electricity. I guess thermal power plants typically have efficiencies of roughly 40%.
In essence we already do this google geothermal energy.
Iou,
The heat transfer through magma is quite poor- even more so when solid as it would be at 700 C . The heat carrying capacity for water is also very high, where as magma's would be low. Your system would need a lot of piping or slow water flow to work.
  • · Replies 39 ·
18K
  • · Replies 17 ·
