| Thread Closed |
Faraday's and Ampere's circuital law |
Share Thread | Thread Tools |
| Apr2-05, 01:04 PM | #1 |
For electric field [tex]E=E_{0}e^{-\alpha}^{z}cos(\omega t)a_{x}[/tex] in free space (J=0), find B that satisfies Faraday’s law in differential form and then determine if the pair of E and B satisfy Ampere’s circuital law in differential form.
[tex]\nabla \times E = -\frac{\partial B}{\partial t}[/tex] Can someone give me hint for next step. Thanks |
| Apr2-05, 02:26 PM | #2 |
Compute the curl.You should have written it (for ease and rigor)
[tex] \vec{E}(z,t)=E_{0}e^{-\alpha z} \cos \omega t \ \vec{i} [/itex] After that,u need to integrate wrt time the negative of the curl you had just computed. Daniel. |
| Apr2-05, 06:21 PM | #3 |
From computed curl:
[tex]\frac{\partial E\vec{i}}{\partial z} = -\frac{\partial B\vec{y}}{\partial t}[/tex] And for B I got: [tex]B =-E_{0}\alpha\omega e^{-\alpha z} \sin \omega t \ \vec{j} [/tex] The answer for B in the book is different so I think I'm doing something wrong |
| Apr4-05, 05:32 AM | #4 |
You might.Here's the curl
[tex]\nabla\times\vec{E}=\left|\begin{array}{ccc}\vec{i}& \vec{j} &\vec{k}\\\frac{\partial}{\partial x}& \frac{\partial}{\partial y}& \frac{\partial}{\partial z}\\ E_{0}e^{-\alpha z}\cos \omega t & 0 & 0 \end{array} \right| [/tex] Okay? Daniel. |
| Apr5-05, 10:52 PM | #5 |
This is what I got for curl
[tex]-E_{0}\alpha e^{-\alpha z} \cos \omega t \ \vec{j} [/tex] then using Faraday's law [tex]\nabla \times E = -\frac{\partial B}{\partial t}[/tex] [tex]B=\frac{E_{0}}{\omega}\alpha e^{-\alpha z} \sin \omega t \ \vec{j} [/tex] I fixed what was wrong, but I still have problem with vector j. Book says it should be z. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Faraday's and Ampere's circuital law
| Ampere's Law | Classical Physics | 1 | ||
| Ampere's Law | Introductory Physics Homework | 1 | ||
| Ampere's Circuital Law | Introductory Physics Homework | 4 | ||
| ampere's circuital law on finite length wire | Classical Physics | 8 | ||
| Ampere's Law | Introductory Physics Homework | 2 | ||
