Express with at least one less pair of absolute value signs
The discussion revolves around the expression ## ||a+b|-|a|-|b|| ## and the challenge of simplifying it by removing at least one pair of absolute value signs. Participants explore various cases and implications of the triangle inequality in the context of absolute values.
  • One participant proposes analyzing different cases to determine which absolute value pairs can be removed without changing the outcome. Others suggest alternative representations of the expression and reference the triangle inequality to explore implications for simplification.
The discussion is active, with participants sharing their analyses and questioning the necessity of separating into multiple cases. Some express uncertainty about their methods while others provide supportive feedback on the approaches taken.
Participants mention various specific cases, including scenarios where one or both variables are zero, and the implications of these cases on the simplification process. There is an acknowledgment of the complexity involved in handling multiple cases.
wifi
We have ## ||a+b|-|a|-|b|| ##. The only way I can think to eliminate one pair of absolute value signs is to consider the cases separately and determine which pair(s) can be removed without affecting the final answer. I'm trying to get better at doing these types of problems, so feel free to scrutinize this analysis.
Case 1: ## a>b>0 ##,
we have ## |a+b-a-b| = 0##.
Case 2a: ## a>0>b ## with ## b>-a \Rightarrow a+b>0##,
we have ## |a+b-a+b| = |2b| = |2| \cdot |b| = -2b ##.
Case 2b: ## a>0>b ## with ## b<-a \Rightarrow a+b<0##,
we have ## |-a-b-a+b| = |-2a| = |-2| \cdot |a| = 2a ##.
Case 3: ## 0>a>b ##,
we have ## |-a-b+a+b| = 0 ##.
After some inspection, one can see that the outermost pair of absolute value signs can be removed without affecting the final answer as long as a negative sign is added in its place. This is possible since the outermost absolute value bar serves only to change the sign in cases 2a and 2b.
So what we have is ## -(|a+b|-|a|-|b|) = |a|+|b|-|a+b| ##.
As a check, let's make sure this yields the same answers as the original expression.
we have ## a+b-a-b = 0##.
we have ## a-b-a-b= -2b ##.
we have ## a-b+a+b = 2a ##.
we have ## -a-b+a+b = 0 ##.
Same as above!
EDIT: Now that I'm thinking about it more, there are several cases I hadn't included:
If ## a=b ## we have ## ||a+a|-|a|-|a|| = ||2a|-|2a||= 0 ##.
If ## a=0, b>0 ## we have ## |b-b|=0 ##.
If ## a=0, b<0 ## we have ## |-b+b|=0 ##.
If ## a>0, b=0 ## we have ## |a-a|=0 ##.
If ## a<0, b=0 ## we have ## |-a+a|=0 ##.
Last but not least, for the trivial case ## a=0, b=0 ## we just have 0.
So we can see that in every case the outer bars may be removed without affecting the final answer. Thus, the answer is the same as described above. Sorry! Hopefully it's correct now.
Can't that be written as ##||a+b|-(|a|+|b|)|##? Are you familiar with the triangle inequality?
The triangle inequality applies to the real number line as a vector space by using the absolute value function as the norm. The triangle inequality states that ##|a+b|\leq|a|+|b|##. What does that imply here?
Yes, I am familiar with that inequality.
This implies that ##|a+b|-(|a|+|b|)\leq 0##. Thus, we can include the negative sign and remove the outermost absolute values bars as I did. Now I feel like what I did was a bit excessive. :redface:
I feel as though I discover only the least clever method for solving problems.
Proof by exhaustion is perfectly acceptable. Though, my suggestion for you would be to wait before you decide to separate it into every single case and solve. That will only work when there is a finite number of cases. I like this depiction:
Ha! I definitely learned my lesson.
  • · Replies 31 ·
  • · Replies 22 ·
