Constructing Trigonometric Identities: A Geometric Approach for Solving ODEs
  • Thread starter Thread starter e^(i Pi)+1=0
    Derive Trig
The discussion revolves around the construction of trigonometric identities, particularly through geometric approaches, in the context of ordinary differential equations. Participants explore how these identities can be derived and the underlying principles that govern their formation.
  • The original poster attempts to understand the geometric nature of trigonometric identities and expresses a desire to derive them. Some participants discuss the definitions of trigonometric functions using the unit circle and question how calculators compute inverse trigonometric functions. Others suggest deriving identities through problem-solving rather than formal derivation.
Participants are actively engaging with the topic, sharing resources and links related to trigonometric identities and their derivations. There is a mix of interpretations and approaches being explored, with no explicit consensus reached yet.
Some participants mention the limitations of calculators and the methods they use, such as lookup tables and algorithms, while also noting that the discussion has veered into related topics like software freedom and cluster computing.
e^(i Pi)+1=0
Can't figure out how they're constructed. I'm guessing it would be geometric in nature. It would be nice to be able to derive at least a few of the ones I inevitably forget through disuse.
Math level: ordinary differential equations.
The trig IDs are geometric - yes.
Look for the trig function definitions that use the unit circle:
http://www.haverford.edu/physics/MathAppendices/Trig_Ident.pdf
I hope this is relevant but can anyone tell me what the calculator does when you press inverse sin cos or tan when you take a value? Say you did inverse cos 1/2, it gives you 60 degrees. You can see it on a triangle if you drew cos .. = A/H = 1/2 But as an equation I can't seem to rearrange it to get that...Does this make sense? Or am I just not using my head
Edit:
A thought, is the calculator just doing some algorithm to get the answer close to the value, not actually finding the value? If so does anyone know what the algorithm is? Like guessing a value that fits.
@tim9000: depends on the calculator - old pocket calculators just used lookup tables and I think that's what most of the math software does these days. You can still buy the dead-tree version of these tables.
Re: main question - I found an old draft I wrote ages ago:
http://www.scribd.com/doc/149266846/Math-Bits
... its got typos and stuff but should be readable. In particular, see fig.3 on p6.
Trig functions are defined in terms of the ratios on the triangle so stuff like ##\cos\theta = A/H## is a definition ... the LHS is a special way of writing the RHS.
Thanks!
Interesting link
Also, you can derive them from simply trying to solve certain trig problems without using them. Although this approach would not function as a proper derivation, and you would have to try a lot of problems.
Simon,
It's funny, lately I've watched quite a few Richard Stallman videos and so it's a coincidence to see your article on Free and open source; also your doc on convincing people to choose freedom over confinement. I think Ted Neslon would agree with you about temporary fixs' becoming perminant.
I'm thinking about making a cluster computer out of 4 raspberry PIs but I've only ever programmed in basic, C and C++ so I don't know if its a good idea.
What do you mean lookup tables?
Yes most calculators give approximate answers two common methods are equal error polynomials series and cordic. For rough answers by hand I use multiples of 15° and 18° to get within 3°.
I imagine he means like a data sheet for the properties of a materials...but not that, along those lines.
Ok, I'll look into "equal error polynomials series and cordic" cheers.
Yeah - I mean a table of data and an algorithm used to look up the answers on them.
http://www.pearsoned.co.nz/student/primary/product-listing-page/product-details-page/?isbn=9780868636313
The forward calculation is easy - so you do it for lots of angles and put them in a table. The inverse problem is then a matter of just running a finger down the entries in the table. You exploit the properties of the trig functions to make the tables smaller. With computers, you can store very big tables and still look up entries very quickly.
Note:
... cluster computing is fun, but a topic for another thread.
... Software freedom is important to scientific and academic work - also a topic for another thread ;)
Note:
If it's published in NZ why is it called 'Statistical and MATH tables'? :P obviously not concentrating on the domestic market (unless they speak more like americans). If I end up starting a thread about either, that I think is of interest I'll send you a link.
Some would say intellectual property is a contradiction in terms, they may be correct.
heh heh - it's the Eton stat and math tables - Eton is in the UK ;D
Actually - wee cultural lesson here: the subject gets abbreviated to "maths" but objects associated with the subject are "math-" whatever. NZ relies on exports so tends to be very globally oriented. Except when it comes to rugby.
Just noticing that OP has yet to respond .. feedback time.
  • Poll Poll
14K
  • Poll Poll
