Second-Order Homogeneous Linear Equation
The discussion focuses on solving the initial value problem for the second-order homogeneous linear equation y'' - 4y' - 5y = 0 with initial conditions y(1) = 0 and y'(1) = 2. The auxiliary equation is correctly identified as r^2 - 4r - 5 = 0, yielding roots r = 5 and r = -1. The general solution is y(x) = C1e^(5x) + C2e^(-1x). The user initially miscalculated the derivatives, leading to incorrect equations for C1 and C2. The correct derivatives are 5C1e^(5x) and -C2e^(-1x), which must be used to solve the system of equations accurately.
  • Understanding of second-order homogeneous linear differential equations
  • Familiarity with solving auxiliary equations
  • Knowledge of initial value problems
  • Proficiency in differentiation of exponential functions
  • Review methods for solving systems of equations, specifically substitution and elimination techniques
  • Study the application of initial conditions in differential equations
  • Learn about the characteristics of exponential functions in differential equations
  • Explore more complex second-order differential equations and their solutions
Students and professionals in mathematics, particularly those studying differential equations, as well as educators looking to enhance their understanding of initial value problems and solution techniques.
andrewdavid
I have this intial value problem: y''-4y'-5y=0, y(1)=0, y'(1)=2. My AUX equation is r^2-4r-5=0. I factor and get r=5, r=-1 and my equation becomes y(x)=C1e^(5x)+C2e^(-1x) (C1 and C2 are constants). I took the derivative of y(x) and then tried to use my initial value's to solve for C1 and C2. I got C1e^5+C2e^(-1)=0 and 5C1e^5-C2e^(-1)=2. For some reason when I solve for C1 or C2 and put them back in the equations it doesn't check out. I'd appreciate any advice to help me find what C1 and C2 are. Thanks!
[tex]C_1e^5 + C_2e^{-1} = 0, \ 5C_1e^5 - C_2e^{-1} = 2 \Longrightarrow 6C_1e^5 = 2 \Longrightarrow C_1 = \frac{1}{3}e^{-5}[/tex]
so
[tex]C_1e^5 + C_2e^{-1} = \frac{1}{3}+C_2e^{-1}=0 \Longrightarrow C_2 = -\frac{e}{3}.[/tex]
It looks like you are on the right track with your solution for the second-order homogeneous linear equation. However, when you took the derivative of y(x), you made a mistake. The derivative of C1e^(5x) is not C1e^5, it is 5C1e^(5x). Similarly, the derivative of C2e^(-1x) is not -C2e^(-1), it is -C2e^(-1x). This error is causing your initial value equations to not check out.
To solve for C1 and C2, you can use the initial value equations as follows:
y(1) = C1e^(5*1) + C2e^(-1*1) = C1e^5 + C2e^(-1) = 0
y'(1) = 5C1e^(5*1) - C2e^(-1*1) = 5C1e^5 - C2e^(-1) = 2
Now you have two equations with two unknowns (C1 and C2). You can solve this system of equations using substitution or elimination to find the values of C1 and C2. Once you have those values, you can plug them back into your original equation to check if they satisfy the initial value problem.
I hope this helps and good luck with your problem!
  • · Replies 36 ·
