Electrical Measurment of Oxide
  • Context: Undergrad
  • Thread starter Thread starter neuro11
The discussion focuses on the electrical measurement of Gallium Oxide (Ga2O3) and emphasizes the importance of selecting an appropriate metal for ohmic contacts. Key considerations include ensuring low resistance at the operating temperature and compatibility with the experimental environment. Gold is commonly recommended for its conductivity and reliability, but alternatives may be available based on specific sample parameters and budget constraints. Consulting with companies that specialize in sample preparation can provide additional insights into suitable contact materials.
  • Understanding of ohmic contacts in electrical measurements
  • Knowledge of material properties, specifically for Ga2O3
  • Familiarity with resistance measurement techniques
  • Budgeting for experimental materials and equipment
  • Research the electrical properties of Ga2O3 for accurate measurement techniques
  • Explore alternative metals for ohmic contacts beyond gold
  • Learn about environmental factors affecting electrode performance
  • Investigate companies that specialize in semiconductor sample preparation
This discussion is beneficial for materials scientists, electrical engineers, and researchers involved in semiconductor technology, particularly those working with Gallium Oxide and electrical measurement techniques.
neuro11
How can i make electrical measurment of Oxide. I know i have make an ohmic contact to use that as an electrode. But how do i decide the metal for this contact. I want to use Ga2O3
Thanks in advance
Depends on the sample parameters and the measurements you want to make and how you are making them.
Usually you want to be sure that almost all the applied voltage is dropped across your sample, so the metal has to have very low resistance in the temperature ranges you are using. It should also withstand the environment the experiment is conducted in and be available to you within your budget ... gold is commonly used for the metal, you may also have another kind of crystal whose properties are well known between your sample and the electrode.
Companies who prepare such samples usually will tell you what sort of contacts are available.
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 58 ·
