Register to reply
One-Way Piezoelectric Material
by dbmorpher
Tags: material, oneway, piezoelectric
Share this thread:
dbmorpher
#1
Jun18-13, 11:04 AM
P: 52
Is there a type of piezoelectric material that only produces a current when bent one way or only bends one way when applied a current?
Phys.Org News Partner Engineering news on Phys.org
Tiny UAVs and hummingbirds are put to test
Britain to trial driverless cars from 2015
NIST corrosion lab tests suggest need for underground gas tank retrofits
Bobbywhy
#2
Jun22-13, 01:03 PM
PF Gold
P: 1,885
Piezoelectric materials generate electric charge (voltage) when stressed/flexed. They move in one direction when a positive voltage is applied and in the other direction when a negative voltage is applied.
Nowhere in the above statements can you find the term "current".
Read about it here: (and the references at the bottom)
http://en.wikipedia.org/wiki/Piezoelectricity
lostminty
#3
Jun26-13, 06:21 AM
P: 77
I imagine if you had the piezoelectric material mounted on a substrate. And it was segregated. then when you bent it to be convex, the piezo electric elements would have gaps in between it and thus be under significantly less stress.
Register to reply
Related Discussions
How to calculate power output in piezoelectric material? Classical Physics 2
Transparent Liquid Piezoelectric Material? Materials & Chemical Engineering 2
How to get C0 of a piezoelectric material. Electrical Engineering 2
How far can an electric field extend beyond a strained piezoelectric material? Classical Physics 0
Question about stresses in material due to elastic and piezoelectric General Physics 8
