Interaction of Photon with water
Regulating temperature in a photoelectrochemical cell can be achieved by immersing it in a water jacket, but concerns about photon collimation arise due to potential attenuation and spreading from the water medium. A narrow, collimated beam can maintain its collimation through various media, but the choice of coolant is crucial, as it should ideally be transparent to the incoming light to minimize transmission loss. UV and visible light can be used effectively, provided the coolant allows for sufficient light transmission. Testing the setup's performance is essential to ensure optimal experimental conditions. Adjustments may be necessary based on the specific design and reactions involved in the photoreactor.
ooiuniscience
Dear all respected expert/collegues,
I'm setting out a photoelectrochemical cell. I'm facing problem to regulate temperature in my photoreactor durng reaction.
Can i just dip the photoreactor inside a big water jacket?
But i wondering incoming photon or light supplied by my Xenon arc lamp become uncollimated after it pass through so many obstacles (consisted fo wall of water jacket which is fabricated flat quartz-made window, followed by flowing water that circulating inside the water jacket then strike onto window of quartz-made photoelectrochemical cell, and finally just reach my thin film inside the photoelectrochemical cell.
P/s advice me on this :-)
Thanks for your fruitful input
Jeff
Science news on Phys.org
Welcome to PF;
What you can do with the photoreactor depends on it's design and what sort of reactions you want to take place.
Keeping it cool would normally involve immersing it in a water bath - or running coolant in tubes around (or through) it.
In general, a collimated beam remains collimated through a range of media provided the beam is narrow.
Intervening material can attenuate and spread the beam ... depending on details not supplied.
Since this is of concern, you should test your rig for it's performance and adjust your experiment design accordingly.
Simon Bridge said:
Welcome to PF;
Hi Simon,
Greeting to you! :)
Yaya, you are right. The major concern is the attention matter due to hampering of the photon with intermediate medium before it strike into my sample. If use coolant, the transmission would be reduced significantly as good collant will have low transmission.
For "a collimated beam remains collimated through a range of media provided the beam is narrow", is it works for UV and visible light bc i tend to harness both of this light to excite my substrate.
However, really thanks for your inputs ;-)
You arrange for the coolant to be transparent to the incoming light or admit the light through a window.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
10K
