Slope at point X and the next closest value to X
  • Context: Undergrad
  • Thread starter Thread starter Atran
    Point Slope Value
The discussion revolves around the behavior of the function f(x) = sin(x) at a specific point, particularly the implications of the slope (first derivative) and curvature (second derivative) on the values of the function at points near x. Participants explore the relationship between the slope at a point and the values of the function at nearby points, focusing on the concepts of local maxima and minima.
  • One participant states that at x = π/2, the slope is zero and the second derivative indicates a negative slope of the first derivative, suggesting that the next closest value to x will have a negative slope for the original function.
  • Another participant questions the definition of "next closest point," arguing that without a specified domain, there is no such point in the real numbers.
  • A clarification is provided that "next closest point" refers to a value greater than x.
  • A participant explains that the second derivative reflects the curvature of the function and discusses the implications of local minima and maxima based on the signs of the first and second derivatives.
  • It is noted that while a local minimum occurs when the second derivative is positive, the converse is not universally applicable, leading to further exploration of the implications of these derivatives.
Participants express differing views on the definition of "next closest point" and the implications of the derivatives. There is no consensus on the interpretation of the relationship between slope and function values at nearby points, and the discussion remains unresolved regarding the clarity of these concepts.
Limitations include the lack of clarity on the domain of the function and the ambiguity surrounding the term "next closest point." The discussion also reflects uncertainty regarding the implications of the second derivative in relation to local extrema.
Atran
Hi,
Say we have [itex]f(x) = sin(x)[/itex], then [itex]f'(x) = cos(x)[/itex] and [itex]f''(x) = -sin(x)[/itex]
Let [itex]x = π/2[/itex], the slope at that point is zero: [itex]cos(x) = 0[/itex]. The second derivative gives, [itex]-sin(x) = -1[/itex]: that means the slope of the first derivative at point x is negative. Thus for the next closest value to x, the slope of the original function is negative.
I want to know why the next closest value, say t, to any x has f(t)>f(x) if the slope at point x is positive, and f(t)<f(x) if the slope at point x is negative?
Thanks for help.
You will have to explain what you mean by "next closest point".
Since you say nothing about the domain of your fuction, the default is the real numbers. And, given a real number, x, there is no "next closest point".
Sorry for that. I mean a value bigger than x, or to the right of x.
Atran said:
Say we have [itex]that means the slope of the first derivative at point x is negative. Thus for the next closest value to x, the slope of the original function is negative.<br /> <br /> .[/itex]
[itex] <br /> The second derivative of f(x) gives the slope of the derivative of f(x), not the slope of f(x) itself. For example, in a scenario from physics, if you throw a ball straight up, then at the time t when it stops going up and starts to fall back down, the velocity is 0. But the acceleration (due to gravity) is negative throughout the whole time that the ball is in motion.[/itex]
That doesn't answer my question. There exist an infinite collection of numbers "bigger than x". what do you mean by "the next closest point"?
Hi there! In essence, the second derivative encodes the curvature of the graph of a function. Let ##f:A\subseteq \mathbb{R}\rightarrow \mathbb{R}## be a function; recall that ##a\in A## is a local minimum (maximum) for ##f## if there exists a ##\delta > 0## such that ##a## is a minimum (maximum) on ##(a - \delta,a+\delta)\cap A##. Recall that this implies, for ##f## differentiable at ##a##, that ##f'(a) = 0##; we say such points are stationary points.
As we know the converse need not hold in general but there is a theorem that will tell us the behavior of the graph of ##f## around stationary points depending on how the second derivative behaves there; it is this that we are interested in. In particular, suppose there exists ##a\in A## such that both ##f'(a)## and ##f''(a)## exist and ##f'(a) = 0##. If ##f''(a) > 0## then ##f## has a local minimum at ##a## and if ##f''(a) < 0## then ##f## has a local maximum at ##a##.
So what does this mean geometrically? Well let's first assume that ##f''(a) > 0##. We then know that there exists, by definition of a local minimum, a neighborhood ##(a - \delta,a+\delta)\cap A## of ##a##, in ##A##, on which ##a## is a minimum, meaning ##f(a)\leq f(x)## for all ##x\in (a - \delta,a+\delta)\cap A##. If you picture this through a graph what you will see is that ##(a,f(a))## is the trough of the graph amongst the nearby points on the graph associated with the aforementioned neighborhood. So it is in effect bending "outwards" near ##(a,f(a))##. Similarly, for ##f''(a) < 0## (local maximum), the graph will bend "inwards" near ##(a,f(a))##.
  • · Replies 53 ·
  • · Replies 46 ·
