Lagrange multipliers and triangles
The discussion focuses on using Lagrange multipliers to demonstrate that the triangle with the maximum area for a fixed perimeter \( p \) is equilateral. The area \( A \) is defined using Heron’s formula: \( A = \sqrt{s(s - x)(s - y)(s - z)} \), where \( s = \frac{p}{2} \). Participants emphasize the importance of setting up the constraint \( x + y + z = p \) and applying Lagrange multipliers to derive the condition \( x = y = z \) without explicitly solving for the side lengths.
  • Understanding of Lagrange multipliers
  • Familiarity with Heron’s formula for triangle area
  • Basic knowledge of calculus and optimization techniques
  • Ability to manipulate algebraic expressions and constraints
  • Study the application of Lagrange multipliers in optimization problems
  • Explore Heron’s formula in depth for various triangle configurations
  • Learn about geometric interpretations of optimization constraints
  • Investigate other methods for maximizing area under constraints, such as the method of substitution
Mathematicians, engineering students, and anyone interested in optimization techniques in geometry will benefit from this discussion.
physicsss
Use Lagrange Multipliers to prove that the triangle with the maximum area that has a given perimeter p is equilateral.
[Hint: Use Heron’s formula for the area of a triangle: A = sqrt[s(s - x)(s - y)(s - z)] where s = p/2 and x, y, and z are the lengths of the sides.]
I have no idea how to do this.
U have a function of 3 varibles (the area) and a constraint depending on these 3 variables (the perimeter is constant).So basically construct the constaint "area" function and then apply the theory...
Daniel.
Are you saying that you don't know what "Lagrange multipliers" are?
The problem is to maximize [tex]A= \sqrt{s(s-x)(s-y)(s-z)}[/tex] subject to the condition x+ y+ z= p.
One nice thing about "Lagrange multipliers" is that we can find important information
(like x= y= z) without having to find x, y, z specifically- eliminate the "multiplier" [tex]\lambda[/tex] from the equations and see what happens.
10K
