Definitions of Measurable Functions
The discussion revolves around the definitions of measurable functions, specifically comparing two definitions based on open sets and Borel sets. Participants explore the implications of these definitions within the context of measure theory, addressing the complexities of Borel sets and their generation.
  • Some participants propose that a function is measurable if the inverse image of every open set is measurable, while others argue that it should be based on Borel sets.
  • One participant expresses uncertainty about whether all Borel sets can be generated through finitely many σ-algebra operations on open sets, suggesting that countably many operations may be necessary.
  • Another participant clarifies that Borel sets can indeed be formed through a process involving countable unions and complements of open sets, but acknowledges the need for a more rigorous approach involving ordinals.
  • A question is raised about whether the set of inverse images of measurable sets under a function forms a σ-algebra.
  • Some participants assert that the set of measurable sets whose inverse images are measurable does form a σ-algebra, citing properties of unions and intersections.
  • One participant mentions the concept of inverse images as a boolean σ-homomorphism, indicating that it preserves operations relevant to σ-algebras.
  • A request for resources on transfinite induction and alternatives to using it in proofs is made, highlighting a gap in background knowledge among some participants.
  • Another participant states that the equivalence of the two definitions can be established without induction, based on the definition of the Borel σ-algebra as the smallest σ-algebra containing open sets.
Participants express differing views on the generation of Borel sets and the equivalence of the definitions of measurable functions. While some agree on the properties of inverse images and σ-algebras, the discussion remains unresolved regarding the necessity of finite versus countable operations in defining Borel sets.
Limitations include the potential misunderstanding of the generation of Borel sets and the implications of using transfinite induction in proofs. The discussion reflects varying levels of familiarity with advanced set theory concepts.
chingkui
I have seen a number of definitions of measurable functions, particularly, for the following two definitions, are they the same?
1) A function f:X->R is measurable iff for every open subset T of R, the inverse image of T is measurable.
2) A function f:X->R is measurable iff for every Borel set B of R, the inverse image of B is measurable.
Here, R is the real line.
I suppose they are the same, but I haven't been able to show they are equivalent (one direction is easy, but the other one, by assuming any open set has measurable inverse image and showing that the inverse image of all Borel set is measurable, doesn't seem to be that easy, since Borel sets in general cannot be easily written down in terms of open sets).
Sure they can -- they're made from applying finitely many σ-algebra operations to open sets. (that is, complement and countable union)
Hi Hurkyl, I am under the impression that a Borel set might not be generated under finitely many σ-algebra operations to open sets. Borel σ-algebra is defined in all the books I read as "the smallest σ-algebra containing the open sets", it is not defined as a constructive process of σ-algebra operations, so, I am not even sure whether countablely many σ-algebra operations to open sets is enough to generate all the Borel sets. That's why I am not sure how to show the two definitions of measurable functions are the same. Are you sure they all can be formed by a finite process? Thanks.
Is the set of inverse images of sets under f a [itex]\sigma[/itex]-algebra?
Bah, you're right, I've made this mistake before, but I've fixed it before. :smile: I meant to say:
Any Borel set can be formed by γ applications of the σ-algebra operations, for some ordinal number γ. (For example, letting γ be any ordinal with cardinality greater than that of P(R) suffices)
More explicitly:
Let B(0) be the set of all open sets.
For any ordinal number α > 0:
Let C(α) be the union of all C(β) with β < α
Then, define B(α) to be the the set of all:
(1) things in C(α)
(2) complements of things in C(α)
(3) things that are countable unions of things in C(α)
You can prove there is an upper bound by some clever theorem of set theory that I don't remember, or simply noting that once you've stopped adding sets, you have the class of Borel sets, and that there are only P(R) many sets. So, B(&gamma;) is the set of Borel sets.
Then, you could do something with transfinite induction. Specifically, if you prove:
(1) If your statement holds for B(0)
(2) If your statement holds for anything in C(α) then it holds for anything in B(α)
Then, by transfinite induction, it holds for all B(α).
Bad question. Better would be:
Is the set of sets whose inverse image under f is measurable a [itex]\sigma[/itex]-algebra?
I think the answer is yes because the inverse image of a union of sets is the union of the inverse images and similarly for intersections. Since the set of measurable sets in the domain is a [itex]\sigma[/itex]-algebra, so is the set of sets in the range whose inverse images are measureable. Hence given (1), the set of sets whose inverse images are measureable is a [itex]\sigma[/itex]-algebra that contains the open sets.
i.e. one of the most useful remarks i recall from measure theory was " the process of taking inverse images is a boolean sigma homomorphism". ... i.e. it preserves all those operations.
Thanks. Seems like transfinite induction is very useful. I don't really have any background in ordinal, cardinal, transfinite induction, etc. can anyone suggest where I can read more (preferably free online lecture note) about them?
Before I have a chance to learn them, does anyone know of any proof that avoid using transfinite induction? Thanks.
You don't actually have to induct, since the borel sigma algebra is defined to be the smallest sigma algebra containing the open sets (strictly speaking I suppose it ought to be the borel sets, but its easy to see that they generate the same borel algebra). So the two definitions are equivalent by fiat.
