Angular Momentum/Rotation Problem
  • Thread starter Thread starter Felix83
    Angular
The discussion centers on determining the hit point (h) above the center of a billiard ball required for it to roll without slipping at a speed of 14.10 m/s. The ball, with a radius of R=7.00 cm and an initial velocity of V0=15.0 m/s, experiences a kinetic coefficient of friction (μ) of 0.214. The solution involves calculating the angular velocity (ω) using the formula V=ωR, resulting in ω=201.43 rad/s. The frictional force (F) is calculated as 0.48 N, leading to a torque (τ) of 0.0336 Nm, which is essential for finding the distance h.
  • Understanding of rolling motion without slipping
  • Familiarity with angular velocity calculations
  • Knowledge of frictional force and its implications in motion
  • Basic principles of torque and moment of inertia
  • Study the relationship between linear velocity and angular velocity in rolling objects
  • Learn about the calculation of frictional forces in different materials
  • Explore the concept of torque and its applications in rotational dynamics
  • Investigate the moment of inertia for various shapes and their significance in motion
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rolling motion and friction in practical applications.
Felix83
A uniform billiard ball with radius R= 7.00 cm rests on a billiard table. At one moment, the ball received a hit from the horizontal direction. Hit point is h above the center of the ball. Then, the ball begins to move with a velocity V0= 15.0 m/s. The kinetic coeffient between table and the slipping ball is 0.214. In order that the ball can roll without slipping with a speed V= 14.10 m/s, what the value of h should be?
I'm stumped on this one, I tried several different ways, all of which the computer tells me is wrong. But the numbers I got didn't make any sense anyway. Any ideas?
How about you post yours...?To see where they went wrong.
Daniel.
It seems like there may be a misunderstanding of the problem here. The question is asking for the value of h, which is the hit point above the center of the ball, in order for the ball to roll without slipping with a speed of 14.10 m/s. This means that the ball will be rolling and not sliding on the table. The initial velocity given (V0=15.0 m/s) is not relevant for this part of the problem.
To solve this problem, we can use the equation for rolling motion without slipping: V=ωR, where V is the linear velocity of the ball, ω is the angular velocity, and R is the radius of the ball. We also know that the kinetic coefficient (μ) between the ball and the table is 0.214.
First, we can find the angular velocity of the ball at a speed of 14.10 m/s by rearranging the equation: ω=V/R. Plugging in the values, we get ω=14.10 m/s ÷ 0.07 m = 201.43 rad/s.
Next, we can use the definition of kinetic coefficient to find the frictional force (F) acting on the ball: F=μmg, where m is the mass of the ball and g is the acceleration due to gravity. We can find the mass of the ball by using the formula for the volume of a sphere: V=4/3πR³. Plugging in the values, we get m=4/3π(0.07 m)³ρ, where ρ is the density of the ball. We can assume a density of 1 g/cm³ for a billiard ball, so m=0.229 kg. Plugging this into the equation for frictional force, we get F=0.214(0.229 kg)(9.8 m/s²)=0.48 N.
Finally, we can use the definition of torque (τ) to find the distance h: τ=FR, where R is the radius of the ball. Plugging in the values, we get τ=0.48 N(0.07 m)=0.0336 Nm. We also know that τ=Iα, where I is the moment of inertia of the ball and α is the angular acceleration. The moment of inertia for a solid sphere is 2/5MR², so I
  • · Replies 60 ·
  • · Replies 17 ·
  • · Replies 29 ·
  • · Replies 18 ·
