Conservation of Momentum (Linear and Angular)
The discussion revolves around a problem involving the conservation of momentum, specifically focusing on a clay mass colliding with a bar on a frictionless table. The original poster attempts to determine the final angular speed of the bar/clay system after the impact, following an initial calculation of the center of mass speed.
  • Participants discuss the application of conservation of angular momentum and question the assumptions regarding the center of mass during the collision. There are attempts to clarify the initial orientation of the bar and its impact on the problem.
Some participants have provided guidance on calculating angular momentum and rotational inertia, while others express uncertainty about the initial conditions and their implications for the problem. Multiple interpretations of the setup are being explored.
There is a lack of clarity regarding the initial position of the bar (vertical or horizontal) and how this affects the angular motion post-collision. The original poster also notes discrepancies in their calculations, indicating potential confusion about the conservation principles involved.
Felix83
On a frictionless table, a glob of clay of mass 0.38 kg strikes a bar of mass 1.76 kg perpendicularly at a point 0.12 m from the center of the bar and sticks to it.
If the bar is 0.66 m long and the clay is moving at 5.7 m/s before striking the bar, what is the final speed of the center of mass?
I found this part to be 1.012 m/s, which is correct, simply using conservation of linear momentum.
I can't figure out the next part:
At what angular speed does the bar/clay system rotate about its center of mass after the impact?
I tried using conservation of angular momentum, which seems to me like it should work, but the computer says it's wrong. I tried it assuming the center of mass doesn't change when the clay hits it, and then did it again figuring in the change in center of mass.
Is the bar initially vertical?
Conservation of angular momentum is the key. Using the center of mass of the composite system as your reference, calculate the angular momentum of the system before the collision. To find the angular speed after the collision, you'll need to find the rotational inertia of the "bar + clay" object about that center of mass.
Thats what I did, the first time it was wrong, I just tried it again and now its right...figures.
It doesn't matter if the bar is vertical or horizontal, all you need to know is that the clay is coming in perpendicular to the bar.
Well its not clear what's going on, if the bar was standing vertically on a table and gets hit, it will rotate about its base, and there's a force of gravity adding to the angular velocity, so things would be more complicated.
18K
  • · Replies 71 ·
  • · Replies 25 ·
12K
