Calculating Equilibrium Concentrations of H+ and HSO3 in SO2-Rainwater Reaction
  • Thread starter Thread starter gunnar
    Ph
The discussion revolves around calculating the equilibrium concentrations of H+ and HSO3- in the reaction of SO2 with rainwater. The context includes the concentration of SO2 in the troposphere and its dissolution in water, leading to the formation of these ions. The equilibrium constant for the reaction is provided, and participants are exploring how to approach the problem without directly solving it.
  • Participants discuss the relationship between the concentrations of H+ and HSO3-, with some suggesting they can be treated as equal under certain assumptions. Questions arise regarding the calculation of SO2 pressure and its conversion to concentration from ppm.
The discussion is ongoing, with participants sharing their attempts and questioning the validity of their calculations. Some guidance has been offered regarding the treatment of concentrations and the use of equilibrium expressions, but no consensus has been reached on the correct approach or calculations.
Participants are working under the assumption that the reaction does not affect the partial pressure of SO2 and are considering standard temperature and pressure conditions for their calculations. There is also a mention of potential discrepancies in the conversion from ppm to concentration.
gunnar
Hi, can someone please give me a hint to this problem?
The concentration of SO2 in the troposphere over a certain region is 0,16 ppm by volume. The gas dissolves in rainwater as follows:
SO2(g) + H2O(l) >> H+(aq) + HSO-3(aq)
Given that the equilibrium constant for the preceding reaction is 1.3e-2. We assume the reaction does not affect the partial pressure of SO2.
I've tried everything I can think of. I am not sure how to handle HSO3 in the equation, is it the same conc. as H+?
In trouble
Assuming the amount of [tex]H^+[/tex] and [tex]HSO_3^-[/tex] was insignificant compared to after the reaction, it's safe to treat the two reactants as having the same concentration.
OK. I treated them as to be the same conc. But how can I get the pressure of SO2?
You need the concentration of S02, try finding it from the data
[tex]Ka=[x][x]/[(concentration~of~S02)-x][/tex], solve for x
[tex]pH=-log[x][/tex]
I solved for x and still don't get it right. I got the pressure of SO2 to be 5,6e-5 atm from the information I got. Used P=nRT/V
Since SO2 is 0,16 ppm it must be 0,16 mg in one liter I assume STP conditions. And I got the MW of SO2 to be 64,07 g/mol
Am I wrong?
why are you using pressure, it's supposed to be in concentration, I'm pretty sure that you can directly convert to concentration from ppm by volume scale. Don't forget to take the negative log of x, this will be your answer.
14K
9K
  • · Replies 20 ·
166K
